I need to replace this coolant pipe as the one currently on the car is leaking from the joint circled. has anyone removed it, it looks possible?...also will replace hoses but having problems finding the part numbers for two pipes that go to the turbo.not much info online about this coolant pipe.
1998 V70T5 coolant pipe removal?
- darylrobert
- Year and Model: V70 240 740t xc70
- Has thanked: 6 times
- Been thanked: 42 times
jcdillin
- Year and Model: 06 V70R
- Been thanked: 3 times
That pipe is held onto the engine by the 2 bolts that go into the head and that small bracket right in the center of the pipe. The pipe just slips into the water pump housing and is sealed by an o-ring 976045.
The nipple labeled number 3 is actually the return from the heater core and number 4 is the pipe that comes from the turbo, I personally wouldn't bother using volvo heater hose, the stuff from the auto parts store works just fine to replace those. Same goes for the #1 short hose. I just took the old stuff in and found the same size.
Have you found a crack at that joint? Almost sounds more like the hose to the coolant expansion tank is leaking and just dripping down to that area.
http://www.volvopartswebstore.com/showA ... bly=240113
- darylrobert
thanks everyone for the replies
- Has thanked: 1505 times
- Been thanked: 3818 times
Boy, that is one nasty confusing diagram
I though the heater cores connect on the rear of the engine..one off the back of the block, and the return to unlabeled connection near the turbo?
I've never seen a P80 with heater hoses returning to front ride side of engine
Greetings!
I know that this is an old topic, but I have a problem with that pipe and I was wondering if somebody knows of what type of material is made this pipe? Is it aluminum or it's iron? I have a very small crack and I think that if it's made of aluminum It could be soldered...
Thank you very much!
Cheers!
Cheers!
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 96 times
- Been thanked: 337 times
It's steel.Andrioman wrote: ↑21 Oct 2020, 04:39 Greetings!
Cheers!![]()
- 484 Views
Last post by erikv11
- 4808 Views
Last post by darrylrobert
