I'm looking at replacing the O2 sensors to see if it will help improve the poor mpg and sooty running ( latter may only be due to lack of use).
I know the upstream sensor is a Bosch 17070 and downstream is a Bosch 16197. Looking at Rock Auto site (seems like best price currently) it states the upstream sensor has a 48" lead and the downstream a 25" lead. Isn't that the wrong way around? I recall having to buy a connecting extender lead for the 98 V70XC we had, but none is listed, so is it required?
Thanks,
2000 V70R - O2 sensors question?
- Has thanked: 2197 times
- Been thanked: 1851 times
jimmy57
- Been thanked: 322 times
That does sound wrong since they connect at the top of transmission where the plugs dock in the plastic carrier plate.
The harness adapter was to stop oil migration through harness that was poisoning the oxygen sensor. That shouldn't be an issue with the 2000 model.
As always jimmy, I bow to your wisdom! Many thanks, and I guess this means no extender required. I'll re-look at where the connections are made to confirm before buying.
- 11708 Views
Last post by packetfire
- 452 Views
- 7016 Views
Last post by oragex
- 211 Views
- 434 Views
Last post by MMT51
