Where does the trip computer get its info from
skloon
Year and Model: 94 850 95 850 04 S60
Post by skloon »
Just finished an RN/Manual swap and see that my trip computer and clock have taken a vacation without me- it doesn't matter which ECU I use, does it get information from the TCU >
cvergi01
Year and Model: 2000 V70XC
Post by cvergi01 »
Yup, from the speed sensor at the final drive is what calculates the miles accumulated. It sends the info to the TCM, which stores it and sends lots of info to the ECM to calculate and play with in regards to timing/fuel trim. The TCM holds the necessary info regarding the transmission/driveline usage to determine torque lockup and other things based on your driving style in the same way that an ECU holds onto the fuel trims and such.
In this way the TCM is the master cylinder and the ECM is the slave cylinder (if they stored info to adjust your pedal response pressure).
I think.
"I'm bored, I'm gonna go work on the car"
"Again?!?"
cvergi01
Post by cvergi01 »
WHOAH....That was confusing.
Washington.
"Again?!?"
Has thanked: 1505 times
Been thanked: 3817 times
Hmmm ...my 1999 has no TCM since it's a manual but trip odometer works fine. My guess is ECU gets info from wheel sensors directly on both cars
skloon
Post by skloon »
I am getting my speed signal from the abs as my transmission is out of a 2004 s60 and the car is a 94
Azik09
Year and Model: S70 T5, 1997
Has thanked: 2 times
Been thanked: 31 times
Post by Azik09 »
TCU and gearbox have not any relation to trip computer. Speed signal is sending by ABS module. Or by separate speed sensor, if your car is pre-1994 Volvo 850.
If my English is bad, please correct me :oops:
skloon
Post by skloon »
it is a 94 turbo, the speedometer works- maybe Ill go with the obvious and check fuses
pkc303
Year and Model: 1995 T-5R Yellow
Been thanked: 3 times
Post by pkc303 »
Well, that explains why the fuel trim was not showing a change, the cruise control not working, and the odometer not moving despite me changing the broken gears. I was able to test the odometer, and it worked with 12v pulse applied. Thanks for the information about the speed sensor for the 1995 850 T5-R
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
