My fuel trims stopped working on scan tool. Car running rich. Temp sensor replaced with Volvo part. All worked well for an hour, then the temp gauge went to zero and lost fuel trim readings. Obd2 shows coolant temp at 195 F.
What controls fuel trim, other than Coolant Temp Sensor? I suspect MAF?
Any thoughts?
Fuel trims
- pkc303
- Year and Model: 1995 T-5R Yellow
- Been thanked: 3 times
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Check connectors for ECT,they corrode with time and usually,cleaning always helps.
The same ECT feeds both...instrument cluster and ecu.
Also,check if wires are not shorted or cut.
Temp gauge behaviour indicate that you lost connection with ect.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- pkc303
Will check tonight. Where is(are) the connection(s)?
- Has thanked: 311 times
- Been thanked: 817 times
ECT mounts into the thermostat housing, the thing with the black wire coming out of it. There is a short wire from the ECT to a black connector, give that a look. Sometimes the connector disintegrates, sometimes the metal connectors corrode, sometimes both.
- misha
You should know that since you replaced it with Volvo part.pkc303 wrote:Will check tonight. Where is(are) the connection(s)?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Rondo
- Year and Model: 2000 S70 GLT/SE
[quote="pkc303]
Any thoughts?[/quote]
O2 sensors also control fuel trim, from what I've read, especially the rear. When I replaced my cat with an aftermarket, my fuel trim was way off. I installed a spacer to get the sensor back to factory depth in the exhaust stream and was back to normal.
Nautic Blue '00 S70 GLT/SE, RIP @ 273625 Miles
Black '00 S70 GLT/SE, 141K Miles
- pkc303
It could, but Imwould expect a code with it. No codes.
Rondo
Mine threw no code at all, but that may be because the sensor was actually working, just the fuel/air mix was off.
Front O2 yes, rear O2 no.
Rear O2 on a P80 is strictly an emissions tattle tail, it has no role in fuel trims. It just reports what is happening in the cat, either turns on the CEL or not, no other function.
- pkc303
Reseated the ECM, seems to work, on the short drive, will try a longer one soon.
- 6176 Views
Last post by Maurice EVO
- 3267 Views
Last post by jakeb123
- 1691 Views
Last post by 850oldschool
- 267 Views
Last post by pgill
- 8532 Views
Last post by Struikrover
