Starting issue XC70 2.4t 2001
b4nditas
Year and Model: XC70 2001
Post by b4nditas »
I have just bought Volvo XC70 2.4t 2001 . At first engine started easily and worked well, no errors and so one. On my way home engine error appears so I stopped the car to check it. When I tried to start the engine again it was starting exactly as it is shown in the video . And now sometimes engine starts quickly with no struggle, but some times it takes a wail to start it.
do you have any ideas what can it be?
b4nditas
Post by b4nditas »
Today I had done diagnostic and it said that there is oxygen sensor error. The mechanic delited error and i have driven around 200 km and error did not show again. But still it does not start easy.
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
What was the error code?
There can be any number of things. I had similar issue, very unpredictable -- could be MAF sensor failing. It measures incoming fresh air.
Like this part https://www.ipdusa.com/products/6581/11 ... low-sensor
Oxygen sensor would not cause engine to not start, unless.
b4nditas
Post by b4nditas »
When I pull the switch away I get motor error and it starts even harder and rpm jumping.
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
RPM jumping is an indication of failing CPS or starter itself, if I remember correctly.
b4nditas
Post by b4nditas »
One more thing when I car stays still temperature is gut right at middle, but when I start driving in 5-10 min it drops two sections down.
vtl
Post by vtl »
Replace thermostat.
zanzabar
Year and Model: '07 V70, '84 245
Been thanked: 4 times
Post by zanzabar »
I agree with VTL, temp issue is stuck open thermostat...weird starting behavior sounds like failing crank or cam position sensor.
VW TDI refugee
LeMons racer ('84 245)
1994 855 (sold)
2007 V70 2.5T daily driver
sergio
Year and Model: S60 2002
Post by sergio »
Hi b4anditas, don't repeat my mistakes, DON'T EVER ever ever START by replacing parts before you're 200% certain your diagnostics are correct.
Crank-crack-no-start can not be caused by a sensor (MAF, MAP etc) that if removed would not affect the engine from starting.
It could be fuel related (pump. filter and wiring)
Few winters back I had the same problem. The wires from fuel sensor were burnt. I replaced the fuel level sensor, since it was NOT reparable. And that was AFTER unnecessary replacement of crank sensor fuel filter and few more stuff.
In my S60 2002, its under the rear seat. Your must be accessible from the trunk. Check it.
These cars have a lot of wires [sometimes I think not less than a commercial airlines ;-) :D ]
If you think some parts must be replaced; try trying them out in a junk yard before buying one.
The correct diagnostic will save $$$$$.
Good luck and keep us posted how you resolve the problem.
S60 2002 180K miles looks and runs like new (except when sulking)
b4nditas
Post by b4nditas »
Today I checked spark switches some of them were white and some black. Tomorrow I will buy new ones and see how engine is reacting.
