I have just bought Volvo XC70 2.4t 2001 . At first engine started easily and worked well, no errors and so one. On my way home engine error appears so I stopped the car to check it. When I tried to start the engine again it was starting exactly as it is shown in the video . And now sometimes engine starts quickly with no struggle, but some times it takes a wail to start it.
do you have any ideas what can it be?
Starting issue XC70 2.4t 2001
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
What was the error code?
There can be any number of things. I had similar issue, very unpredictable -- could be MAF sensor failing. It measures incoming fresh air.
Like this part https://www.ipdusa.com/products/6581/11 ... low-sensor
Oxygen sensor would not cause engine to not start, unless.
zanzabar
- Year and Model: '07 V70, '84 245
- Been thanked: 4 times
I agree with VTL, temp issue is stuck open thermostat...weird starting behavior sounds like failing crank or cam position sensor.
VW TDI refugee
LeMons racer ('84 245)
1994 855 (sold)
2007 V70 2.5T daily driver
1994 855 (sold)
Hi b4anditas, don't repeat my mistakes, DON'T EVER ever ever START by replacing parts before you're 200% certain your diagnostics are correct.
Crank-crack-no-start can not be caused by a sensor (MAF, MAP etc) that if removed would not affect the engine from starting.
It could be fuel related (pump. filter and wiring)
Few winters back I had the same problem. The wires from fuel sensor were burnt. I replaced the fuel level sensor, since it was NOT reparable. And that was AFTER unnecessary replacement of crank sensor fuel filter and few more stuff.
In my S60 2002, its under the rear seat. Your must be accessible from the trunk. Check it.
These cars have a lot of wires [sometimes I think not less than a commercial airlines
If you think some parts must be replaced; try trying them out in a junk yard before buying one.
The correct diagnostic will save $$$$$.
Good luck and keep us posted how you resolve the problem.
S60 2002 180K miles looks and runs like new (except when sulking)
- 2336 Views
Last post by rockhead1002
- 1065 Views
Last post by draser
- 1597 Views
Last post by GBS
- 859 Views
Last post by Chris30537
- 2262 Views
Last post by jaccovdzaag
