It's on the face of the module facing down. That's what the mirror is for.
But.... There are only 3 types of modules that your car will take. STC, TRACS and regular abs. Each of them has various parts numbers, but the unit is the same. So, all you need to know is whether his says stc, Tracs, or regular abs.
$150 is steep for a used module.
Electronics Faulty. ABS Module?
Matty Moo
- Year and Model: 850, 1996
- Been thanked: 30 times
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
Thanks!Matty Moo wrote:It's on the face of the module facing down. That's what the mirror is for.
Ya I was going to try to talk the price down to maybe $100, and ask him if he'll cover it if his used one is faulty and doesn't work on my car. He wants $350 for a rebuilt....
2000 Volvo S70 SE; First Owner; 321km; Retired
2012 Volvo S60 T5 Level II; Gone
- StukaShock
- Year and Model: 1995 850 Turbo
Hello to all, this is my first post.
I have a '95 850 turbo. The speedometer will not register above 45-50mph and will slowly return to zero once the car comes to a complete stop. As soon as I accelerate from a dead stop, the speedo will quickly move to ~50mph on the gauge, but no higher.
When I purchased the car, the speedo worked normally. I noticed this issue became gradual over a period of a few months.
I have not checked any of the pertinent sensors; speed, RPM, ABS module connector, ignition switch. I have read many of the posts here regarding these sensors, my only question is what should I check first? What order of checks should I begin with?
Thanks, any help will be appreciated.
Anthony
Anthony
Current Garage:
1991 244 Saloon, newly acquired
1987 765 Turbo, my sleeper project
1995 854 Turbo, daily driver
1995 BMW 740iL, e38, family car
2000 Jeep Grand Cherokee Laredo, WJ
Wanted:
1984-1993 245, '93 Classic preferred
Wanted:
- Has thanked: 1613 times
- Been thanked: 4075 times
Welcome to MVS Anthony - can you post a video or link to it on you tube of the speedo action?
That sounds strange
That sounds strange
- StukaShock
This link shows my Volvo 850 Turbo dash. Notice that the speedometer quickly rises to 45-50mph, yet the car is only actually traveling at 20-25mph.
This link will show the speedometer slowly return to zero mph, even though the car comes to a full stop.
Notice my other gauges work normally, as they should.
This problem came about last winter and it began gradually. Any ideas, anyone?
Anthony
Anthony
Current Garage:
Wanted:
Wanted:
- darylrobert
- Year and Model: V70 240 740t xc70
- Has thanked: 6 times
- Been thanked: 44 times
Part numbers.
Volvo has a habit of giving one part several different part numbers. I'll list them here.
All 96-98 FWD cars with TRACS. 850, V70, S70, C70. 9162675, 9140774 and 8602266. All of these are identical and compatible with each other.
All 96-98 FWD cars, non-tracs. 850, V70, S70, C70 9140773 and 8602265. All of these are identical and compatible with each other.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Only and ONLY if they are succeded.That means that old number is considered obsolete and new one replaced it.That is all well known in Volvo parts catalogue or database and there is not a single chance of mistake.
You can't say that abs/tracs abs module is compatible with non tracs abs module,if tracs doesn't work with it.It doesn't work because it have NO tracs option.Therefore,it is NOT compatible.
You can install a different part number ecu to your car.It will run...but it will NOT run properly and will have check engine light ON.
The point that it would run with it with a fault doesn't mean that it's compatible with it.
...Volvo has a habit of giving one part several different part numbers
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Matty Moo
You're misinterpreting what I'm saying.
A 96-98 car will accept any 96-98 module. The car doesn't not know what part it is supposed to have whether it's Tracs or not.
The same goes for 99-2000. The part numbers are not preceded, in 99 and 2000 they used all of those individual part numbers and there's no rhyme or reason as to what car received which part number. Also, the part number in the software usually doesn't even match the part number printed on the lid. You have STC, Tracs and plain abs then a load of random part numbers for each type. All of those individual part numbers for each type of abs module are all exactly the same part.
I have two cars to test modules with, a 98 and a 2000. I'm able to test all of the 96-98 units in the 98 and all of the 99-01 units in the 2000. The ecu isn't looking for a match, it's just looking for a functional compatiblel module. I've run thousands of individual modules through each car. No fried ecus and no poor engine management. If that were the case I would have been sued several thousand times by now.
2000 s70 GLT
2014 Ram
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
Sounds like there is still an issue and this is why it keeps toggling the warning lamp.
2023 Lexus RZ450e -66k
