1999 V70R won't stay running after rebuilt ETM
pkc303
Year and Model: 1995 T-5R Yellow
Been thanked: 3 times
Post by pkc303 »
The wires are a good suggestion, had to do the same on both cars.
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
Been thanked: 4068 times
No wires on a 1999
Does the ETM perform the self test on powering up? Whine for 8 seconds, then quiet?
Check the induction pathway and intake manifold for leak on a turbo car
ThommyKent
Year and Model: 91 245 97 850 T5
Been thanked: 5 times
Post by ThommyKent »
Then that`s not the problem.....lol
Has thanked: 2203 times
Been thanked: 1852 times
Maybe time to look to other areas. When did you last change your ignition switch? When you get the rough running, pull over, and try wiggling the key in the switch with the engine running.
Have you check all the heavy wiring: battery, alternator and starter? Does the starter drag? Check the earths are clean and that they are all functioning as they should. Most importantly, pop the top off the main fuse box (the kidney shaped one in front of the brake booster) and check the condition of the B+ cable. Look at the end in the fuse box. It is at the front RH (LH when viewed from the front of the car). It has a nut and all of it should be shiny and bright. This is an issue often overlooked on these cars that Volvo never fixed. The one on mine had melted below the fuse box connection and was not long away from shorting out.
