And no Power.
No check engine light.
This is my son's car, he just called me, car had no power when he pressed the gas
pulled into gas station, found oil under passenger area, he's not sure if it is motor
oil or transmission fluid.
Idle now is very rough, no power, will not rev.
We will need a mechanic in Torrington Connecticut if we can't fix it ourselves. The
car is not worth much so we need a reasonable price.
Ideas on what went wrong?
We have not worked on it for months and have never pulled off a transmission line
or anything like that.
I told him if the oil smells like exhaust then it is engine oil, no report back yet on
that test.
Ideas?
1996 850 Wagon Oil Everywhere Underneath, Very Rough Idle
- Has thanked: 1836 times
- Been thanked: 1709 times
Is car turbo or NA?
PeteB
- Year and Model: 1996 Volvo 850 Wagon
- Has thanked: 57 times
- Been thanked: 11 times
NA, non-turbo
My son says it is engine oil for sure.
He's living about 50 miles from here so if it is an easy fix I can go there
but more likely we will need a good mechanic in Torrington CT.
- dosbricks
- Been thanked: 2 times
On an NA, oil leaking from the passenger side could be a blown front crank seal or front cam seal, but to have a substantial quantity leak out at once sounds more like a ruptured line on the PCV system which could at the same time produce a vacuum leak that could explain the rough idle and power issues. You can replace the PCV system yourself, but not a comfortable undertaking in CT in December unless you have an enclosed work area.
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 113 times
- Been thanked: 115 times
What is the oil level on dipstick?
Was the oil and filter changed recently -- on schedule?
PeteB
We are in luck, have had the most unusually warm weather, and we are going to be in thedosbricks wrote:On an NA, oil leaking from the passenger side could be a blown front crank seal or front cam seal, but to have a substantial quantity leak out at once sounds more like a ruptured line on the PCV system which could at the same time produce a vacuum leak that could explain the rough idle and power issues. You can replace the PCV system yourself, but not a comfortable undertaking in CT in December unless you have an enclosed work area.
60s for the next few days - no problem.
So, assuming we inspect it and find that it is the PCV system, where is the best write up on
how to do the job?
And where do we get the best kit with original long lasting parts?
Thanks, very much!
PeteB
The oil and filter were changed 3 or 4 months ago and it is due for another change.xHeart wrote:What is the oil level on dipstick?
bskeels
- Year and Model: 1997 Volvo 960
- Been thanked: 3 times
Robert, rspi on this site, has a series of good utube videos for repairs. You have a few choices in your area, fcpeuro.com in Milford CT, Tasca in Cranston, RI, and Premier Volvo in Watertown, CT.So, assuming we inspect it and find that it is the PCV system, where is the best write up on
how to do the job?
The Fleet
2012 Ram 2500
97 Volvo 960
98 V70 AWD (208000+)
66 Volvo 122s sedan project
98 Volvo V70 XC (151,000+) parts car
08 Volvo V50 T5
"Human history becomes more and more a race between education and catastrophe" - H. G. Wells
2012 Ram 2500
97 Volvo 960
08 Volvo V50 T5
- pkc303
- Year and Model: 1995 T-5R Yellow
Does it have an oil line going to the radiator? I know the turbos have them, not sure about the NA.
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
