Help,
My 2007 s60 had the battery drained.
Then I used a key to open trunk & charged battery
(causing alarm to go off using ignition key to turn off alarm)
disconnect battery & charge (battery was too dead to keep alarm off before charge)
car fine started up fine...
I used a innova (i3100) code reader to clear any remaining codes
(i turned off the ignition the removed reader & shutdown reader, no off before removal? weird)
now without opening the hood the car fires clearly but will not run.
alarm issue?
Disconnecting battery for 30 min see what happens (cross fingers) & strangly that reset did the trick!
Thanks
Keith
s60 2007 - clear codes fires won't run
- 1534 Views
Last post by SuperHerman
- 1869 Views
- 902 Views
- 469 Views
- 2185 Views
Last post by precopster
