ongoing oil leak
nthnnxn
Year and Model: 2000 S70
ongoing oil leak
Post by nthnnxn »
Hello again,
2000 S70 Base model is continuing to gather oil on top of the head. I have replaced the oil fill cap and cvvt solenoid gasket. I even put a hose clamp on the PTC hose... STILL POOLING UP :cry:
Where is this oil coming from??
clifford06
Year and Model: 2000 T5
Has thanked: 6 times
Been thanked: 4 times
Post by clifford06 »
Greetings. Clean area. Start car and let idle. Watch around black 10mm bolts. Had similar leak. I had one bolt that was only finger thight .Good luck.
Been thanked: 471 times
Post by cn90 »
Oil Cap SEAL!
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
What brand of oil cap did you use?
85 GLH, 367 whp
00 Insight, 72 mpg
nthnnxn
Post by nthnnxn »
Ok...So turns out at least 4 bolts are loose...but for some reason they will not torque down. Threads look good and NOT crossed...do I get new bolts, or R/R all bolts I have now? Dealer wants $13 per bolt and reccomends all 12 bolts be new.
nthnnxn
Post by nthnnxn »
Oil Cap is genuine volvo and came with new seal...I made the mistake buying cheap aftermarket CRAP before getting the REAL DEAL...LESSON LEARNED!
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Leave it unless it's leaking more than 1 quart per 1000 miles.
nthnnxn
Post by nthnnxn »
I am losing about 1qt/250 miles... I can spin the untorqued bolts with my fingers only...
Has thanked: 292 times
Been thanked: 765 times
If the bolts look good then the threads inside the head are likely stripped. Unfortunately, stripping of the soft, aluminum head is more likely than of the steel threads on the bolts. Test this by pulling a good bolt, one that threads in properly, from another hole using a socket, and testing it in a hole where the bolt is spinning. If that good bolt also spins then the problem is the threads, not the bolt. Check each one of the four holes.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
nthnnxn
Post by nthnnxn »
Thanks! So assuming the head threads are bad...whats the fix?
