ongoing oil leak
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
HeliCoil. Drill, tap, put wire coil inside, and put use old bolts. (make sure the bolt threads are not damaged first)
But this isn't going to fix the "1qt/250 miles" issue.
I would start with the PCV system first for your oil disappearing issue.
85 GLH, 367 whp
00 Insight, 72 mpg
nthnnxn
Year and Model: 2000 S70
Has thanked: 3 times
Been thanked: 4 times
Post by nthnnxn »
For pcv system i have done the dipstik tube and engine fill "glove" diagnostic methods...no smoke and the glove didnt move...
nthnnxn
Post by nthnnxn »
After playing around with the bolt swapping...the questionable bolts torqued down well in the other holes and the already known "good" bolts torqued down BETTER but not perfect in the questionable holes... I suppose this means i will be nursing this issue until the holes get re-drilled? Is there anything more i can do to help secure the bolts (adhesives)?
nthnnxn
Post by nthnnxn »
75 miles later 4 bad holes turned into 2... I went snooping for more oil leaks and found plenty of oil build up on the driver side of the engine...cleaned it up but still not sure exactly where its coming from
Been thanked: 504 times
Post by cn90 »
I'd do this:
- Loosen the bolt a bit, apply some RTV around the head. Gently torque it down.
Are the threads stripped?
nthnnxn
Post by nthnnxn »
Took the cam sensor cover off and saw this...
Should there be a seal inside here?
Post by cn90 »
Cam seals are for model up to 1998.
Starting 1999, just a plastic cover, which is usually destroyed by the process of removal.
Search for posts by Ozark Lee...
nthnnxn
Post by nthnnxn »
Sorry, i'm a bit confused. I thought that is the exhaust cam cover (metal) i removed to unveil the oil leak. What is the metal cover i removed to show in the pic? And what is the part called that shows the oil leak?
nthnnxn
Post by nthnnxn »
There is a seal inside there behind a bolted down cylinder wheel lookin thing. Any danger if I remove it to replace the seal?
Has thanked: 311 times
Been thanked: 817 times
No danger at all. The 99 comes without a seal there but many people put them in anyway. Go with Corteco, don't go with a cheapo seal it will leak.
