Hi again guys... I resolved the starting issue in my other post just needed a new battery... Now I'm having another issue... I'll be driving along and all of a sudden the temp guage shoots up to half then back down to a quarter after 5-10 mins... I'm thinking thermostat but maybe I'm wrong... Any ideas lads???
Steve
95 850 GLT 2.4 vrooooooom
88 MR2 bone stock
84 Mustang 3.9
Toyota Camry XLE
94 Honda Civic EJ
06 Civic LX
04 VW Jetta 2.0
91 Prelude Si 4ws
95 Volvo 850 GLT thermostat issue
BlackyChan91
- Year and Model: 95 850 GLT
95 850 GLT 2.4 128k
88 Toyota MR2 bone stock
91 Honda Prelude Si 4ws
94 Civic ej
06 Civic LX
84 Mustang 3.9
94 Camry XLE
96 Jeep Gr. Cherokee Limited 5.2
94 Civic ej
06 Civic LX
84 Mustang 3.9
94 Camry XLE
- Been thanked: 504 times
- Tstat: use Wahler $18 or so. Search forum for the tricks on how to undo the stubborn Torx bolts.
- ECT: use Volvo or SWF brand, around $50. I wrote the DIY in forum.
- Has thanked: 312 times
- Been thanked: 818 times
More likely the problem is the ECT sensor = Engine Coolant Temp sensor, and most likely is an ECT connection issue. First thing to do is to check the connector where it gets crudded up with coolant over the years, and sometimes falls apart. If the connections appear good then probably need to replace the ECT, but replace both that and the stat, as alluded to by cn90.
- Has thanked: 1611 times
- Been thanked: 4075 times
There are good sets of resistance measurements in threads on this Board and the VRD as well
BlackyChan91
I'll look into both and reply asap... Should I be worried about possible overheating?
95 850 GLT 2.4 128k
94 Civic ej
06 Civic LX
84 Mustang 3.9
94 Camry XLE
94 Civic ej
06 Civic LX
84 Mustang 3.9
94 Camry XLE
I would be pretty careful about using the car, yes. As you have probably surmised, there is a very low chance that the temp gauge is showing actual temperature, due to some kind of erratic thermostat opening and closing or another clog in the cooling system.
- 9 Replies
- 2367 Views
Last post by misha
- 925 Views
- 1862 Views
Last post by kahl
- 676 Views
Last post by BlackyChan91
- 9 Replies
- 1684 Views
