Volvo 850 Transmission Replacement Tutorial
This topic is in the MVS Volvo Repair Database » 1995 Volvo 850 Transmission replacement
whoa
Year and Model: 850 Turbo Wagon 1996
Post by whoa »
I've been hoping for a good walkthrough on this job, and lo and behold Matt comes up with an astounding one. Thanks for the superb work!
I have a RMS leak, and I've had the parts for this for well over a year. Even built an engine support and a transmission cradle to fit on my floor jack. Seeing this write-up is sobering, though, and I'm starting to think maybe the leak isn't all THAT bad.
1996 850 Turbo Wagon
wheelsup
Year and Model:
Has thanked: 16 times
Been thanked: 22 times
Post by wheelsup »
whoa wrote:I've been hoping for a good walkthrough on this job, and lo and behold Matt comes up with an astounding one. Thanks for the superb work!
I hear ya. Just took it for 400 mile round trip no oil that I can find thank god! It's nice to not have that RMS leak anymore. I do have a jerry rigged setup that takes crankcase pressure from my dipstick tube and routes it under the car - now that I know the leak is gone I can work on routing that into the intake manifold or try what someone else suggested and use bigger tubing into the PCV system (posted recently). Just a good feeling!
1995 850 GLT Wagon w/ 200,000 miles
Nob00st
Year and Model: 1995 854 GLT
Post by Nob00st »
wheelsup, it's funny - I've been looking around for a DIY on how to replace a trans (I just got a 95 GLT that needs a new trans soon) and found this post - and I too live in Raleigh!
Thank you for the guide!
Barnett
Year and Model: 1997 850 GLT Wagon
Post by Barnett »
Hey wheelsup!
I just joined to thank you for this write up!!! I am going to undertake this with an 850 wagon. I just purchased it and then it developed a pretty good RMS leak. Thanks for a great very detailed write up!
97' 850 GLT Wagon, 275000kms
wheelsup
Year and Model:
Post by wheelsup »
Barnett wrote:Hey wheelsup!
You're welcome!
vjaneczko
Year and Model: 2006 S60R
Been thanked: 7 times
Post by vjaneczko »
I know it's been a few years but I'm wondering if you recall disconnecting the evap hose, the one that runs from the canister down along the front of the subframe, then behind the front engine mount and between subframe and sway bar. Do you happen to remember if it gets disconnected at the canister or behind the swaybar? I don't want to yank on it at the wrong spot!
1997 855 GLT - R.I.P.
2006 S60R - For ME!
greg850r
Year and Model: a long list
Has thanked: 5 times
Been thanked: 26 times
Post by greg850r »
Does anyone know if the clutch fork can be removed without separating the engine and tranny. Anyone got a picture of the part itself? I can't seem to find one online.
Thanks
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
lrwagon96
Year and Model: 1996 855 HP
Post by lrwagon96 »
Thanks so much for the insight and convincing evidence that the damaged flywheel will likely remain in the car as I'm reluctant to bring it to a shop for seven hours of work (over $1,000) and $400 for a new flywheel doesn't make too much sense for my 30 year old 850 turbo wagon. Still, knowing how it should be done is really helpful to confirm that the shop did it right.
If only I had a garage to take the car apart, tools more than I can afford (although I did buy a 30mm socket and 1/2" socket wrench to move the crank 5' to the next set of teeth), and days to commit to the task.
Great wrote up!
Gary D, NYC
Been thanked: 4071 times
I’m in port Jeff area if you get motivated to pull the engine. I’ve got an engine puller
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
lrwagon96 wrote: 27 Jun 2025, 15:51 Thanks so much for the insight and convincing evidence that the damaged flywheel will likely remain in the car as I'm reluctant to bring it to a shop for seven hours of work (over $1,000) and $400 for a new flywheel doesn't make too much sense for my 30 year old 850 turbo wagon. Still, knowing how it should be done is really helpful to confirm that the shop did it right.
Great wrote up!
Gary D, NYC
850, Turbo, Wagon, and Manual aren't words that go together very often in the States. Unless the car has lots of salt worm rot, it likely deserves another chance. Dr. Abscate would be a fine fellow to get to know.
