2000 V70XC Park Brake dash light
DrJammer
Year and Model: 2000 V70XC - 195k
Post by DrJammer »
Howdy, my park brake dash light is visible when I have the key in position I/II. However, when I pull the park brake on, no light shows up. I replaced the e brake cables and shoes myself last summer and passed state inspection and the light was working for awhile. (used awesome DIY - https://www.matthewsvolvosite.com/forums ... ht#p312113 )
Anyone have some attack points? I checked under the car and the cables look fine to me, and the car seems to hold.
Is there something in the center console I can go after, or is this a possible snafu in the wiring from park brake to dash bulb?
Ex-Volvos
2004 v70 N/A - traded in at 75k
2008 S60 - leased
1998 S70 T5 - might still have her if I knew about this forum when I owned it
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
The switch is behind the parking brake handle in the center console and that would be the logical place to start.
hbsluna8
Year and Model: 2002 V70
Post by hbsluna8 »
DrJammer, did you find a fix for this? I am having the same issue except I never replace the e-brake cables or shoes (those components are working fine).
Anyone else have any input on this issue?
DrJammer wrote:Howdy, my park brake dash light is visible when I have the key in position I/II. However, when I pull the park brake on, no light shows up. I replaced the e brake cables and shoes myself last summer and passed state inspection and the light was working for awhile. (used awesome DIY - https://www.matthewsvolvosite.com/forums ... ht#p312113 )
Been thanked: 4068 times
Screen Shot 2016-01-06 at 1.59.02 PM.png (126.03 KiB) Viewed 856 times
Item (2) is the connector for the parking brake lamp switch , this is under the cover on a 1999 but I think your 2000 is the same
hbsluna8
Post by hbsluna8 »
Thanks for the reply. I removed the center console yesterday and that connector was where it should be. From what I saw, when you activate the e-brake, it causes the connector to pull away and stop making contact. When the e-brake is removed, the connection resumes. Is that how it's designed to work? Nothing happened when I pulled the connector. I will be using a volt meter to see if the wire has current.
