how much power do i want this car to make?
- Has thanked: 2856 times
- Been thanked: 1332 times
I'd do an IC before a RIP kit also.
- Has thanked: 311 times
- Been thanked: 817 times
Your R came stock with a 15g. All 850s came with either a 15g (all HPTs) or a 13g (all LPTs i.e. only the 97 GLT). I don't know what the numbers mean either, beyond varying directly with size/boost.biohazrd76 wrote:This makes sense, thanks. I'm wondering what turbo came stock in my 97r . 16t? Or 18t what do these numbers mean, I know it refers to size, but is this the turbo inside dia. Or teeth on spline. I am wondering
If you bump the turbo, then bump the injectors and the tune to match.
biohazrd76
- Year and Model: 1997 850R
So then my root question becomes how much power will this 15g turbo make when fully optimized. By that I mean big cats and downtube, and why are some guys running e85 in big power volvos. Am I wasting money on 94 octane?
1997 850 R, black.
Ipd HD tcv, msd coil pack, ipd HD cbv, ipd stage 1 ecu flash, iridium plugs,heavy gauge plug wires, airbox cover delete, k&N cone filter directly before maf, ipd HD end links.
Graveyard: 1993 850 glt, NA 168 bhp,gold. Hit and run 2009 totaled
1995 850 Turbo, 222 bhp totaled
E85 power explained.
Your turbo is just as much a bottleneck as everything else at this point. No more, no less. You have headroom with a 15.
Want the most power for the least outlay of time and money? Add a boost gauge and manual boost controller. More power for $100 than absolutely anything else.
- Has thanked: 2199 times
- Been thanked: 1851 times
In reply to Roberts question, I am taking the 'claimed' values from Rica. This is based on a standard 2000 'R' and should not require any other mods. The only other mod is a K&N filter. They also claim (more importantly) 300ft/lb torque. Is it real? Not sure, but as I have the Softloader, I can re-tune to standard and it is noticeably slower, and the torque builds more slowly. The claim is the tune puts out 18psi (confirmed by dealer) turbo pressure on the 19T turbo. I also have a Xemodex ETM, but that should not have any real affect. Add that the 2000 has closer ration 5 speed auto it does pull more than well enough for me, whatever the real numbers are.
biohazrd76
Right now I have the one from ipd. I have also read Lucky's thing on mbc and ecu tamed boost, so I don't want to bend anything. I was satisfied when I had this setup in my 95 turbo, with the ipd tune and parts the car was snap fast and traction would come loose on demand... So I'm going to see what I can do with this cars stock turbo and intercooler. Once I have begun to develop target boost and a proper exhaust .will go to dyno and post!!
1997 850 R, black.
Wish you the best of luck. Upgrading to a T16 will give you much better boost is you find the 15 is not cutting it. Lucky also has upgrade kits for the turbos in billet form, so may be another way to tackle more power.
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
It is really, really hard for me to believe the "RIP kit" does anything at all. There might be a cosmetic benefit if you like the way the shiny tubes look, but wrap some tinfoil around the existing ones and save yourself a couple hundo. Never seen one that wasn't absurdly priced.
biohazrd76
A bit of info from the hvac industry: every time air must flow around a corner it's pressure is lessened. Therefore the mass air flow is less. So the less bends an intake has the more power it will make. Our stock ic piping is probably 14" longer than necessary. Will be putting the scan tool on my car today for first time, cel or MIL is burned out I'm guessing
1997 850 R, black.
tryingbe
- Year and Model: None
- Been thanked: 26 times
This one is almost free.j-dawg wrote:Never seen one that wasn't absurdly priced.
http://www.vpcuk.org/forums/showthread. ... etto-style!
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
- 18 Replies
- 10955 Views
Last post by erikv11
- 350 Views
Last post by hausmeister
- 1726 Views
Last post by Freestate
- 10 Replies
- 1642 Views
Last post by MrAl
- 901 Views
Last post by Stoffelmans
