Torx set recommendation for CAM Seal job
iRenaissanceMan
Year and Model: 2010 XC70 T6
Post by iRenaissanceMan »
Hi,
I'm right about to start the job to replace the Exhaust and intake CAM seals on a 2004 XC90 2.5T FWD. However, I hear there's a T50 bolt that's going to take upwards of 100ft-lbs of force. I do not want to strip the bolt.
I have a few Harbor freights really close buy. I was curious if anyone has any experience with the HF torque set:
http://www.harborfreight.com/9-piece-38 ... 67887.html
I was thinking this specific set because:
1. It's cheap
2. Looks sturdy
3. Looks short enough to possibly be useful for the serpentine tensioner
I know there are higher quality equipment out there - craftsman, snap-on. I'm not looking for the Rolls-Royce of tools... just looking for the set that'll do the job, every time.
Please let me know if you have any experience on this job. Any advice (regarding tool or even the job itself) would be greatly appreciated.
Thanks!
Ringo
Year and Model: 2006 70XC
Has thanked: 33 times
Post by Ringo »
I've used these and found them to be tough cookies
https://www.amazon.com/gp/product/B0002SQU9U
2006 XC70 2.5T auto (B5254T2) 125K 2nd owner
1999 V70 XC 2.4T auto (B5254T) 250K Trans failed 2018
1967 122S 2-door auto (B18B) 125K (ex-wife got it 1991)
bskeels
Year and Model: 1997 Volvo 960
Been thanked: 3 times
Post by bskeels »
I have some experience with the job, the actual size of the socket you need is a T55. You also need the cam locking tool and some patience. There is a specific procedure on re-aligning the vvt, which can be found on this site.
The Fleet
2012 Ram 2500
97 Volvo 960
98 V70 AWD (208000+)
66 Volvo 122s sedan project
98 Volvo V70 XC (151,000+) parts car
08 Volvo V50 T5
"Human history becomes more and more a race between education and catastrophe" - H. G. Wells
Been thanked: 504 times
Post by cn90 »
Make sure you spend time reading through the thread below...
Large oil leak after replacing exhaust camshaft (cvvt) seal - help needed!
http://volvoforums.com/forum/volvo-xc90 ... 251/page2/
PS: Re Cam Seals, stick to Corteco brand, which is OEM. Search rmeuropean dot com to see if they have it. Do NOT use SKF.
Post by cn90 »
Also, when installing any CAM seals, watch for seal "folding over". The idea is to oil the shaft beforehand and go very slow, making sure the seal does not fold over. More detail below:
https://www.matthewsvolvosite.com/forums ... hp?t=73530
Also, search forum for PVC Coupler (The plumbing coupler used in drain/waste system) I used as a tool to press it in.
iRenaissanceMan
cn90 wrote:Make sure you spend time reading through the thread below...
uh oh... i just bought seals off FCP. They're both Elring brand. Are those acceptable? which ones are SKF? Thanks!
iRenaissanceMan
cn90 wrote:Also, when installing any CAM seals, watch for seal "folding over". The idea is to oil the shaft beforehand and go very slow, making sure the seal does not fold over. More detail below:
Thanks! I'm pretty familiar (very familiar) with plumbing. Which size coupler did you use? I saw people mention 1.5" PVC coupler for a different vehicle (S60?), but mentioned the XC90 would require a different size. They didn't mention which. I'll go searching if you don't recall which size coupler. There aren't many so I could go out and buy a 1.5" and 2" coupler from the orange store.
Thanks again!
Post by cn90 »
Go to rmeuropean dot com, and search for Corteco Cam Seals.
Corteco is what came from factory. About $8/each.
You will regret later if you use Elring, it will likely leak (search matthews Volvo forum and you will see).
Once you receive the Corteco seals, bring it to Home Depot etc. and find a PVC coupler that matches.
Post by cn90 »
Ringo wrote:I've used these and found them to be tough cookies
1+,
Another Vote for Lisle tool!
iRenaissanceMan
cn90 wrote:Go to rmeuropean dot com, and search for Corteco Cam Seals.
Thanks! I've done just that! I do not want to repeat this job!
