P0305 Code (misfire code) Topic is solved
adbalt
Year and Model: 1998
Post by adbalt »
Checked again and its the spark plug well directly behind the oil fill cap that was filled. The top around the cap also also had oil pooled. I will change the cap and see if that solves that as well as change the wires and plugs to see if the misfire code goes away. I will update when finished and advise if that solves the issues. Thanks for everyones help!
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Good practice to change the rubber seal on the oil filler cap at every or every other change.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
adbalt
Post by adbalt »
Thanks for the tip. I didn't realize the gasket came off and was replaceable.
E Showell
Post by E Showell »
An expensive alternative is the get an IPD billet cap with special seal. The seal is supposed to last a good long time.
'95 855 auto (sold)
adbalt
Post by adbalt »
One last question. If some of the plug wires were arcing would that indicate the distributor cap is OK or should I replace everything?
Has thanked: 312 times
Been thanked: 818 times
Yeah, just replace the gasket, the oil cap itself is probably fine.
The problem could be just wires, just cap, or both. You can't really tell without more testing. If the cap is not Bosch I would replace it, can you wait as long as it would take for obayha's to arrive?
adbalt
Post by adbalt »
Just wanted to give an update. Took me awhile to get back at it. I recently changed the oil filler cap and that solved the problem of the oil leaking onto the top of the plug wells. I changed the distributor cap, plugs, and wires. Although the car runs great it still sets a P0305 code. Not sure why but for now I'm going to continue to drive. Only issue other than the code being set off is a rough idle when stopped. Not sure if the code and rough idle are related. Anyway thanks for everyones help and any ideas feel free to let me know.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Has thanked: 1611 times
Been thanked: 4075 times
With a new cap rotor wires and plugs - a misfire code is a cue for a compression test on that cylinder - and the rest while you have the tools out.
songzunhuang
Year and Model: 98 V70 T5
Has thanked: 2 times
Been thanked: 30 times
Post by songzunhuang »
adbalt wrote:Just wanted to give an update. Took me awhile to get back at it. I recently changed the oil filler cap and that solved the problem of the oil leaking onto the top of the plug wells. I changed the distributor cap, plugs, and wires. Although the car runs great it still sets a P0305 code. Not sure why but for now I'm going to continue to drive. Only issue other than the code being set off is a rough idle when stopped. Not sure if the code and rough idle are related. Anyway thanks for everyones help and any ideas feel free to let me know.
Wondering if you were able to get this figured out. My car recently started to do the exact same ting with the same code. I changed the plug wires and checked the cap and plugs. The cap and rotor looked fine and the plug in #5 didn't look wet, but I regapped it and replaced it. A trick I tried was to swap plugs on cylinder #5 (misfiring) with a plug from another cylinder to see if the misfire moved with the cylinder, indicating a plug issue. Well, I regret to report that it didn't work. I am still getting the P0305.
I did notice damage on the wiring harness leading to plug #5. I could see the copper as the insulation had been rubbed through. I taped it up with some electrical tape, but it wasn't the problem. The code came back.
Damage to the wiring harness for the #5 injector.
Screen Shot 2016-04-11 at 8.32.26 AM.png (798.31 KiB) Viewed 1943 times
Beautiful blue NGK wires. Too bad they are just going to be covered up.
Screen Shot 2016-04-11 at 8.31.23 AM.png (815.94 KiB) Viewed 1943 times
I'm scratching my head a bit. If it's a head gasket or valve issue, its gets real tricky as I don't know if I have the patience or time to do this myself. At the cost of a head re-build, I am not sure it's worth it on a 245K mile car. I'm going to have my daughter drive it a bit more and then I'll do the compression test in the near future. We will see how it goes.
Song Huang
1998 V70 T5 - Hurt your eyes red
2000 Honda S2000 - Berlina Black
1984 BMW 633CSi - Dolphin Grey
2024 Lexus - Eminent White Pearl
2004 XC90 T6 AWD Ruby red (RIP)
