Engine blowing up, sort of.
- Has thanked: 1611 times
- Been thanked: 4072 times
Almost sounds like you are getting fuel into the crankcase somehow. I'm worried you havemajor mechanical problems in the bottom end and should be looking at motor options. Large crankcase pressure isn't good. There is no way you want this thing to start until you figure this out,
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
I don't think your only problem is the PCV. Have you checked fuel and spark?
The problem may include but not be limited to your PCV.
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Try disconnecting the hose from the oil trap box to the cam cover. (in between spark plugs, see if that is where the white smoke is coming from. while doing the diagnosis, pull your fuel pump relay and coil wire, then check and see if cranking pressure is coming from the upper hose, and if the dipstick tube and oil cap stop smoking.
This will just show that the crankcase is pressurizing the system. Sounds like a compression check is in order, like a LOT of pressure is going through PCV, may indicate weak rings. Or may not.
Also, before you do PCV, read cn90's thread on DIY PCV hose redo, If you have a lot of blow-by, but not too low of compression, this might be the ticket for you..
Current Volvos:
TripleEight
- Year and Model: 1995 850
Thanks for all the input guys, I'll check cn90's pcv redo, search feature isn't recognizing anything with less that 4 letters....
So I got the pcv kit from fcpeuro, most parts Volvo genuine, the trap looked different (a bit compact) but ended up fitting perfectly. Long story short, still getting smoke coming out of the oil fill and dipstick like a steam engine.
I'm only cranking the car for 5 seconds intervals as I'm afraid of the explosion.
Also I'm not sure is if it was smoking from the crankcase before the problem, or it's because of this problem as I never checked.
Old oil trap was clogged at the bottom but it seems like it wasn't the problem as there's enough space for gas to get through. Cleaned out the hole where the trap connects to the block, Cleaned out EGR which was completely blocked. Everything else was fine just caked on carbon here and there.
I haven't checked the timing yet.
So is there anything else other than the piston ring seal that would spit smoke? As i will have to give up on the car if it was the ring seal.
TripleEight
Im gonna check again if I'm getting actual sparks from every plugs.
But there must be something igniting in the cylinders if I'm getting smoke from a freezing cold engine right?
TripleEight
So I checked the Sparks and they are all igniting dull orange, probably due to low battery.
I decided to crank the car for a while and just see what happens and it started! for a couple of seconds and stopped, very excited I tuned the engine again and it goes POOM!! White smoke everywhere again, oil all over the cover, top pcv tube blown off. (And this is with the dipstick out and oil fill cap half tight)
The smoke smells kind of like burnt rubber but not unburned fuel and the initial smoke or vapor that pumps out of the dipstick before the explosion also smells like burnt something.
Before this all happened I also tried cranking without the fuel injectors plugged and/or the spark unplugged and I still saw smoke coming out of the oil fill mouth.
Yes, i tried unplugging the top pcv pipe only and it had blow by gas/smoke pumping out just like the dipstick hole and oil fill hole.
I read n90s pcv fix after I did my pcv job
. But I doubt that the small tube is at fault for the huge pressure build up and the explosion, not to mention with the dipstick being pulled out and oil fill cap loose.
Now I'm just stumped.
TripleEight
I will grab an compression test kit at autozone today if they have them, thanks
- Has thanked: 311 times
- Been thanked: 818 times
Good advice.tryingbe wrote: ... Did you do a compression test yet?
- 869 Views
Last post by polskamafia mjl
- 2015 Views
- 962 Views
Last post by ShadyMilkMan
- 772 Views
Last post by 122sPhil
- 4008 Views
Last post by matthew1
