´96 850 R ABS error code 441
B234R
Year and Model: 850 1996
Post by B234R »
Hi, three years after my 850 has again the ABS/TRACS lights blues!
I have scanned my car with VOL-FCR and the code is "ABS-441: Main Relay in Control Module". I didn´t clear it off. I turned off the engine and restarted, and the lights were off. But I have the annual inspection on thursday and I´m a bit worried if they appear again. Although I think my 850 can pass with the ABS lights on (if it was the airbag light on, it would fail), if it´s easy to repair I would give it a shot before the inspection. What does error code 441 mean?
Thanks!
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Not sure but you could probably remove the bulb and they would not know it's missing. They usually look for the Check Engine light.
Matty Moo
Year and Model: 850, 1996
Been thanked: 30 times
Post by Matty Moo »
Pull the main harness off and make sure there isn't any corrosion in the socket. That code isn't a module fault, it usually pops up with low/flaky voltage.
Clear it and carry on.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
B234R
Post by B234R »
The harness seems fine, and I´ve cleared the code. Today the ABS/TRACS lights have remained off.
Here the Check Engine isn´t important (they check emissions anyway) but the Airbag light is a fail.
Let´s cross fingers for the inspection! Thanks a lot.
