I have purchased a replacement engine for my v70r and need to know if there is a date code on the belt that would determine if the timing belt has been replaced? The timing belt has a volvo part number but no obvious date code.
Thanks
Chirs
Is there a date code on volvo timing belts
fairmont50
- Year and Model: 1999 v70r
- Been thanked: 3 times
Look all around the engine compartment for a sticker. How many miles are on it? If the engine isn't in yet it is a cinch to replace with it out.
- Been thanked: 504 times
When in doubt, replace the TB, tensioner and idler pulleys. The TB kit is $120 from Volvo online (not from local Nebraska dealer, who set its own price!).
fairmont50
Unfortunately, I only have the engine, not the car (there was no timing belt sticker on the timing cover). I was hoping to avoid the $200 cost of a timing kit is it has already been done. At 150000, the engine is overdue for a belt if it has not been done yet.
Chris
This may end up being a double post.
Chris
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
If you are replacing the engine and plan to keep the car, why risk the belt, water pump, etc. It's to easy to replace out of the car. A belt is about $30. If your stuff was good, you can use it for another 50,000 miles.
fairmont50
If there is no date code on the belt (and it appears that there is not), I will replace the belt, pulleys, tensioner and water pump. I was just hoping to avoid that if possible.
Chris
Chris
- misha
- Has thanked: 155 times
- Been thanked: 432 times
It should be....my Volvo belts have a date of manufacture on them.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 808 Views
Last post by 850 LPT
- 999 Views
Last post by DavidE7
- 5184 Views
Last post by Bragg Creek
- 2315 Views
Last post by Jeney
- 24 Replies
- 4596 Views
