Why does my customers 1994 Volvo 850 GLT Non-Turbo Engine Oil Smoke?
caj767314922
- Year and Model: 2011Volvo
Every time my customers drive, not even that far, my customers stop and check my engine, and the engine oil tank is hot. My customers open the engine oil cap and so much hot steam/smoke/oil bursts out. My customers know you're not supposed to open if after you drive right away, but my customers don't think there should be that much heat and oil pressure after that not even a minute of driving. Oil sputters onto the roof of my customers hood after a few minutes of driving as well. My customers checked the cap and dipstick seals and they seem fine.
- Has thanked: 1611 times
- Been thanked: 4075 times
If you charge double for speculation, you find you get fewer requests for the same.
I think this is a bit tough to define what pressure is normal in this way, but splatting oil around an open crankcase cap is normal, IMHE
- dyn blin
- Year and Model: 1997 850 Wgn
- Been thanked: 2 times
Gasket for the oil caps are quick to fail, and likely needs changed if oil is slipping past when closed, however, not likely the causal issue
PCV system likely needs overhaul. Lots of good info in the DIY's on diagnosis and replacement/repair
'97 850 GLT Wagon- Driving to see 300k in the rearview
- 5628 Views
Last post by precopster
- 2758 Views
- 12 Replies
- 2752 Views
- 12 Replies
- 2612 Views
Last post by erikv11
- 1465 Views
Last post by misha
