2002 V70 Passenger Window/Lock switch
hcritz
Year and Model: 2000 v70
Post by hcritz »
I know there have been several post on what these switches control and such. Mine died after a battery disconnect and reconnect. Pretty sure it's a bad capacitor on the board...at some point I may try to replace them and see if that fixes the switch.
My question is, can a switch from another V70 be installed and reprogramed to work? My dealer is telling me that it's a one time deal. Once the switch is programed for the car it can't be reprogramed to work with another. If true...I'll have to purchase a new switch and have them program it.
Any info will be appreciated.
Thanks,
Ed
Ed
1995 850 turbo wagon 340,000
2000 v70 280,000
2002 v70 140,000
Has thanked: 1503 times
Been thanked: 3817 times
Ed - are we talking about a switch on the door or a switchblade type key fob used to unlock the car ??
The first is just a mechanical, the latter has to be programmed in VIDA from 1999 on..
hcritz
Post by hcritz »
Thanks for the reply abscate
This is the Electronic window/lock switch on the door.
What I need to know is if a used switch can be reprogramed with VIDA to work on my car.
I think a new switch is almost 500 dollars and then has to be programed.
Ed
2000 v70 280,000
2002 v70 140,000
hcritz
Post by hcritz »
Any Ideas Guys?
Still wondering if I have to spend 6-700 bucks to get my window to work!?!?!?
Ed
2000 v70 280,000
2002 v70 140,000
Dannybv
Year and Model: 2001 V70
Post by Dannybv »
I'm in the same boat, can I pick up a boneyard replacement or do I have to use the dealer?
Sorry I didn't respond to Ed
The switch on the P2 models is fully electronic and is listed as part number
31334466 $414 (SEP 2019)
FCP says it may require programming to work on install.
93SCMax
Year and Model: 2001 V70 T5 mt
Has thanked: 36 times
Been thanked: 44 times
Post by 93SCMax »
Dannybv wrote: 04 Sep 2019, 13:43 I'm in the same boat, can I pick up a boneyard replacement or do I have to use the dealer?
Yes, it's plug n play. Get the same PN as in your vehicle. Make sure the battery is disconnected prior to removal of old unit and install of junkyard unit. Follow battery reconnect procedure.
There is no need for a new switch or going to the dealer!
