how much power do i want this car to make?
biohazrd76
- Year and Model: 1997 850R
I will continue to post here thanks
1997 850 R, black.
Ipd HD tcv, msd coil pack, ipd HD cbv, ipd stage 1 ecu flash, iridium plugs,heavy gauge plug wires, airbox cover delete, k&N cone filter directly before maf, ipd HD end links.
Graveyard: 1993 850 glt, NA 168 bhp,gold. Hit and run 2009 totaled
1995 850 Turbo, 222 bhp totaled
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
What was causing the 1/2 boost, the chipped ECU?
Abscate is trying to be helpful, this forum is meant for people who are having issues with their car.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
biohazrd76
Yes, but this is an ecu from a 95 turbo, put into a 97 r. Also the vacuum tree had a 4" long piece of tube going nowhere, used the free nipple for a boost gauge. If anyone Can post a comprehensive diagram of vacuum tree hose routing this would help many people. I would say most half boosting 850s more than likely have a leak in vacuum lines or intake and intercooler hoses. If the car has ANY vacuum escape it will skew the tcv, causing the computer to permanently roll back target boost until it gets a happy reading from the rest of the engines sensors saying "OK to boost" more or less...
1997 850 R, black.
- Has thanked: 2856 times
- Been thanked: 1332 times
Uncapped, I presume? If on the other hand it was capped and not cracked, that was not the cause of the leak/reduced boost, something else was.Also the vacuum tree had a 4" long piece of tube going nowhere...
biohazrd76
Let me now take a moment to thank you all. Over the past 10 years of owning these cars I have visited this site countless times. Each time walking away with a new and useful piece of info. Yes the hose was uncapped. And thanks for the diagram.
1997 850 R, black.
"I'm bored, I'm gonna go work on the car"
"Again?!?"
"Again?!?"
biohazrd76
I figure what better day to take the 850. As a snowstorm approaches the northeast....since the bit of maintenance it's running great. Idle smooth only after warm up. Running on 93 getting excellent mileage considering driver behavior...... Now just that passenger wiper to move again. So desperate to drive only with one working wiper. Tyvek tape over broken headlight lens . Drivers door only opens from outside. Heat stuck on defrost. The little things!!!!!
1997 850 R, black.
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
biohazrd76 wrote:I figure what better day to take the 850. As a snowstorm approaches the northeast....since the bit of maintenance it's running great. Idle smooth only after warm up. Running on 93 getting excellent mileage considering driver behavior...... Now just that passenger wiper to move again. So desperate to drive only with one working wiper. Tyvek tape over broken headlight lens . Drivers door only opens from outside. Heat stuck on defrost. The little things!!!!!
If you decide to take out the wiper assembly, make sure you take pics of how it's all aligned. That thing is an absolute PITA to try and get back to normal if it gets f-ed up...
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
biohazrd76
Thanks , whatever is broken I can hear it slide inside the cowl on sharp turns !! I'm now finding out no wiper fluid is making it to the nozzles. What a day. In true Volvo fashion all the things you need stop working...
1997 850 R, black.
I think it's going to miss you in Pitt, but DC, PHL, NYC, BOS are screwed
- 18 Replies
- 10973 Views
Last post by erikv11
- 353 Views
Last post by hausmeister
- 1734 Views
Last post by Freestate
- 10 Replies
- 1651 Views
Last post by MrAl
- 904 Views
Last post by Stoffelmans
