I now notice a surging Idle and when I turn the car off, I can hear a high pitch noise near the ETM is that normal?
no check engine light or ETS light
installed the ETM
- Year and Model: Lots
- Been thanked: 128 times
Was the new ETM matched to your car and programmed or just installed with fingers crossed that it's a match for your car? Did you buy part number 36050563? If so it will have a recent fw pre-installed for 2001 turbo but it may not necessarily match your car's ECM (engine control) version.
If the ETM continues to whine with ignition in Pos II and engine off I can tell you quite certainly that it's not a match.
I hear that high pitch noise when the ignition is off and the key out of the ignition.
don't know why the video uploaded upside down , but here's the noise
ChrisatXeMODeX
- Year and Model: 2013 S60 AWD
- Been thanked: 2 times
The ETM should not whine with the key out of the ignition. Disconnect the ETM plug and see if you have 12V there with the key out. Link to ETM diagnostic flow chart.http://xemodex.com/us/knowledgebase/etm ... 1999-2004/
ChrisatXeMODeX
Pull the engine management relay out, it might be stuck.
With that part number this has to either be a V70 2001 or 2002 non turbo or a S60 2001 or 2002 non turbo. If you bought a used 8644344 it won't suit your car withour programming.
I checked that previous post of yours and I can see that you have a 2000 model V70. You most definitely have the wrong firmware in the ETM.
- 884 Views
Last post by kahl
- 4528 Views
Last post by ajwsurfer
- 4983 Views
Last post by antonevane
- 15 Replies
- 6788 Views
- 4734 Views
Last post by firstv70volvo
