850 loves cold start, hates warm weather start
Warren Watson
- Year and Model: 850 1994
My 1994 Volvo 850 will start up like a pro in sub 20 degree F. weather. Above 50 it is a hard start. In either case I get it started and if I kill it, it will start up no problem within 5 mins. of killing it. 20 minutes later, i try to start it and takes for ever. Note: i have a new fuel pump relay, cleaned MAF, new cam sensor, temp. sensor, rotor and distr. cap,,new plugs, fuel filter, vacuum elbows, and, if i check fuel at schraeder valve, i have fuel squirt out. What is left?
- Has thanked: 311 times
- Been thanked: 818 times
The symptoms almost match a heat soak situation, which would be strongly suggestive of an electronics issue. Temp goes up, resistance increases, system behaves differently.
What brand is the MAF? At any rate I would unplug the MAF, then see how that affects the starting behavior. Of course this test will set a CEL for the MAF, so you will need an OBD reader to reset that.
Cleaning the MAF does no harm when the right product is used so it was a good move doing that, but FYI it is rarely useful unless the filament is super dirty (like visibly oily, etc).
Also I would check the condition of the wiring inside the ECT connector, the metal can get corroded and the wires frayed etc.
- 2235 Views
Last post by matomorizo
- 3560 Views
Last post by 93ForMe
- 1168 Views
Last post by Cailin
- 906 Views
Last post by matthew1
- 707 Views
Last post by MoVolvos
