shutter during acceleration
tom4342
Year and Model: 1998 v70 awd
Post by tom4342 »
Would running regular gas in a 98 v70 awd turbo cause a slight shuttering during acceleration? It never did before.
Tom Hood
Has thanked: 292 times
Been thanked: 765 times
Not likely, no. Ill effects of regular gas (from running lean) are cumulative over time.
However if you got "bad gas" which does happen this time of year, yes.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
tom4342
Post by tom4342 »
Well been running regular for 3 or 4 years so maybe its added up
Tom Hood
Ah ok I thought you meant just one tank of regular.
The turbo engine is made to run like 91 octane. The main risk of running regular (lower octane, like 87 or even 89) is burning an exhaust valve, which would be worse symptoms than stuttering during acceleration. You could try switching to higher octane, the car's ECU will figure out that you did and adjust, and it is a good idea, but I doubt it will fix the stuttering.
Are there any codes, is the Check Engine light illuminated?
'06 S60 R, 197k
benpineapple
Year and Model: '06 V50 T5, '13 XC90
Has thanked: 5 times
Been thanked: 4 times
Post by benpineapple »
If you have an OBD reader, I'd reset the ECU once you fill with premium. Shudder could be a lot of things, especially if it's a rogue symptom with now CEL.
Does the V70 feel like it has much power, or is it pretty tame typically?
2006 V50 T5 [190,xxxM]
2013 XC90 FWD [80,xxxM]
2001 V70 X/C AWD [sold at 120xxxM],1998 V70 AWD [RIP at 249,255M], 1990 240 [SOLD at 220xxxM]
tom4342
Post by tom4342 »
A family member has the car so am going by what she is telling apparently it still has plenty of power might tell her to run a can of sea foam through it
Tom Hood
tom4342
Post by tom4342 »
Only code showing is large evaporative leak which i have yet to nail down however that never seemed to affect performance.
Tom Hood
If it is still stuttering after getting new, known-to-be-good gas, I would consider, in order:
- ignition parts. What is the age on cap-rotor-wires-plugs?
- throttle position sensor. The only way I know to test this is to swap in a good one, like from a junkyard. Not a great troubleshooting strategy if you don;t have a spare part.
- MAF sensor, but these often (but not always) throw a code. What brand is it, what is the age on it?
- vacuum leak. Again, it should throw a code, but they don't always.
'06 S60 R, 197k
Has thanked: 1505 times
Been thanked: 3818 times
Is it shuddering ( low frequency vibration) or stuttering (m-M-missing) ??
Cees Klumper
Year and Model: 2002 S80 T6
Has thanked: 41 times
Been thanked: 28 times
Post by Cees Klumper »
Could it be a worn driveshaft bearing?
