SOLVED - '96 850 no start
Has thanked: 1611 times
Been thanked: 4075 times
If starting fluid improved the firing of the engine that points to a fuel problem...either too much or too little
Check the fuel pressure at the rail to see if it's in specs. Check the fuel pressure regulator and see if fuel has entered the diaphragm through the hose.
There is a thread here with the actual ECT resistance measurements
Teddy1975
Year and Model: 2007 V50
Been thanked: 7 times
Post by Teddy1975 »
It's alive!
I swapped the spark plugs to some el cheapo plugs from the nearest car parts supplier as well as the air filter. When I replaced the air filter, I noticed the air intake hose, between the filter box and throttle body, had a 2" long hole. Almost like someone took a knife and cut into it. I put a bandaid of vulcanized tape on it, really wrapped it up tight and nice. I know that won't hold forever but for now at least the engine starts on first try.
I will still be swapping the spark plugs to volvo OE, but at least now it is not a priority. I actually forgot to check if the ECT code is still there, I'll check that later.
Thanks to all for your help and suggestions.
Later has come and gone, there are no more codes on the CI :D :D
Current: V50 2.0D, 2007, 6 speed manual
Previous: 850 2.0L N/A, 4 door 1996 manual, 740 2.3L N/A, 5 door 1992 manual, and S70 2.5T 1999 manual
