Knock Sensor Replacement
tylka
Year and Model:
Post by tylka »
MY car is giving me codes that the front Knock sensor is bad. My question is will I have to take the manifold off to get to it, or can I replace the sensors without going through all that trouble? Thank you.
White850Turbo
Year and Model:
Post by White850Turbo »
You have to take the manifold off. It's not that hard to do. I even wrote a guide to removal of the manifold if you're interested.
-Sean
1995 850 Turbo (Extensively Modded)
1998 S70 T5 (Almost Stock)
tylka
Year and Model:
Post by tylka »
If you don't mind, let me know how to take the manifold off. Haven't done it on the 850 yet. Thanks.
hernhaw
Year and Model:
Post by hernhaw »
White850Turbo wrote:You have to take the manifold off. It's not that hard to do. I even wrote a guide to removal of the manifold if you're interested.
Hi Sean:
Where can I find your guide for the removal of the manifold? I have a 1-4-3 code on my recently purchased '94 850 Turbo & would like to attempt doing it myself or actually, having someone more knowledgable help me.
Thx!
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
I had posted a diagram on here some time ago on how to remove the intake manifold but couldn't find it. I'm hoping this will help.
pfeener
Year and Model:
Post by pfeener »
If you're going to take off the intake manifold, you might want to consider rebuilding the PCV system at the same time. FCP sells a kit with all the parts.
MadeInJapan
You are completely correct, don't consider it...DO IT....the pcv system clogging is responsible for (in my opinion) over 90% of all engine trouble in these cars.
ccgaudette
Year and Model:
Post by ccgaudette »
:!: What MIJ said -- only more-so.
In an older 850/s70, in the process of taking the intake manifold off you are likely to break the PCV hose. The PCV hose gets brittle with time and heat. Once the hose is broken the engine will not run right.
I did not, nor would I ever, take the intake manifold off my car without a new PCV kit and intake manifold gasket already at hand.
1993 U.S. Volvo 850 GLT sedan, 20-valve, N.A., 4-speed Auto. Trans., 180,000 miles
JFO
Year and Model: '98 S70 GLT
Post by JFO »
I just completed changing the PCV system with the kit from FCP. The pictures in this link will show you how to do the knock sensor and while there, you can do the PCV which is visible in the pics. You don't need to disconnect the fuel lines at the rear of the engine as shown on page2. It took me about 3 hours or less I think.
http://volvospeed.com/Repair/knock_sensor.pdf
Jim
'98 S70 Turbo GLT
280,000 km
ccgaudette
Year and Model:
JFO wrote:I just completed changing the PCV system with the kit from FCP. The pictures in this link will show you how to do the knock sensor and while there, you can do the PCV which is visible in the pics. You don't need to disconnect the fuel lines at the rear of the engine as shown on page2. It took me about 3 hours or less I think.
Jim
Very well done JFO!
Definitely should have steam cleaned my engine bay first. The squeamish will not want to look at the few pictures I rounded-up! :wink:
http://web.mac.com/cjgaudette/iWeb/Roof ... ifold.html
