Fuel Pump Check Topic is solved
AdamS70T5
Year and Model: 1999 S70 T5
Post by AdamS70T5 »
Yes that is true, my car does not have a fuel pressure regulator.
UPDATE.
So i got the new pump in and started and unfortunately the same problem happened. It started, idled for 2-3 seconds, sputtered and then died.
I decided to jump the relay again, and this time it worked.
I left the car idling for 5 minutes then revved it a little and it worked fine.
I put the relay back in and it won't start.
So it would seem that both my fuel pump and my fuel pump relay were bad. I must have really bad luck :(
So I'll get a new relay. I hope that this is the last thing that I need.
Been thanked: 504 times
Post by cn90 »
Maybe the root cause was the fuel relay all along.
This is why I recommend that people carry a Torx Set and a jumper wire (with fuse) in the glove box.
The diagnosis with the jumper wire is quick and definitive!
This is an example of my jumper wire...
Has thanked: 312 times
Been thanked: 818 times
So it was the relay all along but hey, failure of the old fuel pumps is pretty common too now you know you are covered. :)
AdamS70T5
Post by AdamS70T5 »
Update.
So its been about 3 weeks so far with the new fuel pump relay, and everything works.
So I have installed a new fuel pump, new fuel pump relay and new fuel filter, so as erikv11 said I'm covered.
Thanks again for all the help guys. :)
