Knock Sensor Replacement
White850Turbo
- Year and Model:
You have to take the manifold off. It's not that hard to do. I even wrote a guide to removal of the manifold if you're interested.
-Sean
1995 850 Turbo (Extensively Modded)
1998 S70 T5 (Almost Stock)
Hi Sean:White850Turbo wrote:You have to take the manifold off. It's not that hard to do. I even wrote a guide to removal of the manifold if you're interested.
Where can I find your guide for the removal of the manifold? I have a 1-4-3 code on my recently purchased '94 850 Turbo & would like to attempt doing it myself or actually, having someone more knowledgable help me.
Thx!
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
I had posted a diagram on here some time ago on how to remove the intake manifold but couldn't find it. I'm hoping this will help.
MadeInJapan
You are completely correct, don't consider it...DO IT....the pcv system clogging is responsible for (in my opinion) over 90% of all engine trouble in these cars.
ccgaudette
- Year and Model:
In an older 850/s70, in the process of taking the intake manifold off you are likely to break the PCV hose. The PCV hose gets brittle with time and heat. Once the hose is broken the engine will not run right.
I did not, nor would I ever, take the intake manifold off my car without a new PCV kit and intake manifold gasket already at hand.
♂ 1993 U.S. Volvo 850 GLT sedan, 20-valve, N.A., 4-speed Auto. Trans., 180,000 miles
JFO
- Year and Model: '98 S70 GLT
I just completed changing the PCV system with the kit from FCP. The pictures in this link will show you how to do the knock sensor and while there, you can do the PCV which is visible in the pics. You don't need to disconnect the fuel lines at the rear of the engine as shown on page2. It took me about 3 hours or less I think.
http://volvospeed.com/Repair/knock_sensor.pdf
Jim
Jim
'98 S70 Turbo GLT
280,000 km
280,000 km
ccgaudette
- Year and Model:
Very well done JFO!JFO wrote:I just completed changing the PCV system with the kit from FCP. The pictures in this link will show you how to do the knock sensor and while there, you can do the PCV which is visible in the pics. You don't need to disconnect the fuel lines at the rear of the engine as shown on page2. It took me about 3 hours or less I think.
Jim
Definitely should have steam cleaned my engine bay first. The squeamish will not want to look at the few pictures I rounded-up!
http://web.mac.com/cjgaudette/iWeb/Roof ... ifold.html
- 2051 Views
Last post by cn90
- 522 Views
Last post by Mr. Detail
- 1774 Views
Last post by 5ft24
- 758 Views
- 9 Replies
- 1537 Views
Last post by southofmotown
