CEL - miss fire cyl 3
ds2728
Year and Model: v70 1998
Post by ds2728 »
Hello,
I have a 1999 S70 2.4 turbo AWD
My car started missing, got the codes read, miss fire cyl 3. So I bought 1 coil pack, as I have a similar issue in the past. I installed coil pack into cyl 3, car still missed, so I swaped cyl 3 with cyl 2 to see if I could move the problem. Car started running even worse, so I went back and had the codes read again. This time it said cyl 2, 3 and 5.
I decided to just buy all new coil packs and plugs, I just installed them and I still have a miss. I got my codes read yet again and found out that I have miss fire on cyl 3. I swapped back in one of the old ones that I am sure is good, came off cyl 1. I still have a miss.
I am now at a loss of what could be wrong. Any ideas on what to do/check next would be appreciated.
Thaanks, dave
bskeels
Year and Model: 1997 Volvo 960
Been thanked: 3 times
Post by bskeels »
check your compression would be a start, I have typically found when I had a miss that it was a vacuum line that either broke, rotted of came off somewhere.
The Fleet
2012 Ram 2500
97 Volvo 960
98 V70 AWD (208000+)
66 Volvo 122s sedan project
98 Volvo V70 XC (151,000+) parts car
08 Volvo V50 T5
"Human history becomes more and more a race between education and catastrophe" - H. G. Wells
101
Year and Model: 98 V70GLT, 98 S70T5M
Post by 101 »
+1 on the compression test.
Rule out an engine mechanical issue before anything else.
101
1998 white V70 GLT 230K "Elsa"
1998 white S70 T5m 180K "Anna"
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Probably a burnt valve. Disconnect the fuel injector if you are still driving the car, until you get it fixed. Dumping fuel into the cylinder is bad for the engine and exhaust.
ds2728
Post by ds2728 »
Thank you for the responses. I checked compression tonight and found cyl's 1,2,4,5 had 110lbs and cyl 3 has 0 lbs pressure.
I have a curious question, I have owned volvo's for 20 years and the only ones that have ever given me issues are the 2 2.4 turbo's AWD, one is a 1999 and the othe was a 2000. Both of these cars have ended up with burnt valves, this one only has 157k miles on it. I have a 98 850 nonturbo with 200k no issues.
Is there something that causes these cars to have an issue with burnt valves and is there anything that could have prevented the issue.
Thanks again for the responses, at least I have solved the why it is missing. Not very happy about it and not sure what I am going to do about it. Will it hurt it to drive on 4 cyl if I have the injector unplugged for cyl 3?
Thanks again, Dave
Been thanked: 4069 times
You can drive it sedately with the injector unplugged. We had someone here drive 8000 miles once, I think.
Head off and rework it for < 1000 bucks and you can get another 150k miles
Has thanked: 311 times
Been thanked: 817 times
The "why burnt valve?" question gets posted about a lot. For sure leaky valve stem seals is part of the problem. Maybe running low octane fuel, too. Lots of pet theories on here, do some searching if you are curious.
It is not peculiar to the turbo models, I have had it happen twice, both NAs.
ds2728
Post by ds2728 »
Thanks again for the replies, I really didn't want to do another head job on one of these volvo's. But the car isn't worth paying a shop 2-3k to have it done either. So now I have to decide to junk it or fix it.
rspi
Post by rspi »
