I own a 1999 V70 GLT with 192,600 miles on it. There are several issues, but I'll start with the simplest. My sun roof will not close all the way. What could be the problem? Could it be blocked by something like s rock or twig?
Sun Roof issue
- phils94850
- Year and Model: 2009 s60 turbo
welcome to MVS ! I would check the track and make sure nothing is blocking it. You can try moving it around up and down etc while closing to see if you can feel where its getting stuck.
1996 Platinum Edition
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
I had the same problem, there is a reset procedure, you unlock and lock your car door a certain number of times. I can't remember how many.
Also, make sure it is well lubed, if it faces a lot of resistance, it will bounce back.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
- phils94850
Lock and unlock the door THREE times with you key
- 534 Views
Last post by rspi
- 1184 Views
Last post by packetfire
- 16 Replies
- 2385 Views
Last post by vtl
- 844 Views
Last post by ovlov058R
- 1366 Views
Last post by tommyaleks
