Recurring 2-1-2 94 850
skloon
Year and Model: 94 850 95 850 04 S60
Post by skloon »
My 850 is throwing a 212 code indicating the front o2 sensor- this is a new sensor, I have checked all the vacuum lines which are also new, there is no elbow under the intake manifold but I do see reference that it can be caused by the fuel evap system- how do I check this ?
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
What brand is replacement sensor?
Are the numbers on it the same like from the old one?
Phase 1 850 up to '95 had two types of o2 sensors.Titania & Zirconia.Titania works on resistance and,the most usual one,Zirconia works on voltage difference and they are not interchangeable.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2861 times
Been thanked: 1332 times
Post by matthew1 »
Which brand sensor? Are you sure you got the connector clipped together well?
Also -> Amazon link
skloon
Post by skloon »
No idea of the brand of sensor or number, to add to the difficulty I am running an RN swap with an ECU from a 95 manual turbo- the car runs fine just throws the code about every 50km
misha
Post by misha »
'95 should carry Motronic 4.3 and '94 should have Jetronic engine management.They are not interchangeable.
Hmmmm....i'm surprised the car even starts and run unless u.s cars had motronic management even in '94.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
skloon
Post by skloon »
I have used my 94 ECU as well I get the 212 plus another one for the missing transmission- the 95 was a Canadian car and everything looked identical to my 94 except no EGR -which has been deleted and all the holes filled
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
94 850 turbo used M 4.3
212 on which setting?
https://www.matthewsvolvosite.com/read-codes-volvo-850
Was the TCU removed?
85 GLH, 367 whp
00 Insight, 72 mpg
skloon
Post by skloon »
I am getting the error from A2, the TCU has been removed as it has been manual swapped, I am using the 95 ECU as it was a manual turbo car- and was 4.3 as is mine I do have a 4.4 ECU from a manual but it was a lpt so I don't want to use that
misha
Post by misha »
Don't use 4.4 in a 4.3 car without some wiring modifications.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
tryingbe
Post by tryingbe »
misha wrote:Don't use 4.4 in a 4.3 car without some wiring modifications.
Negative. No wiring modification needed anymore.
http://m44.wikia.com/wiki/M4.4_A/C_Converison
85 GLH, 367 whp
00 Insight, 72 mpg
