Re-check the fitment of the PCV oil canister pipes at the top. A recent post on the subject of continued pressure turned out the poster had switched the 2 top pipes in error. Reversing them corrected the issue.
Like the guys are saying, if the problem wasn't there before you took stuff apart, then the place to go is back over the area you worked on and around the area you worked on to see if anything got broken or damaged or missed on re-build.
Neil
2000 volvo c70 crank, wont start after ptc valve cleaning
- Has thanked: 2200 times
FastYellow
- Year and Model: 850 T5-R 1995
No start trouble shooting
MusicBuy
- Year and Model: 2000 c70
So the mechanic came to check it the other day and tested the compression. The car indeed did have some compression and was as follows: cylinder1: 95, cylinder2: 98, cylinder3: 110, cylinder4: 130, cylinder5: 120. Not quite exact but about how much i remember-ish. The mechanic found that two ignition coils went bad and i replaced tho's but no luck. The car will not start.precopster wrote:Fully charge the battery because if it IS lawnmower syndrome and the battery is healthy it will crank extremely fast with a fully charged battery.
The PTC element is of no consequence; something else is at play here.
MusicBuy
The mechanic also checked for codes and no codes were found. Only other stuff apeared on his obd device like bad convertible motor, bad windows etc. i do remember i saw something about bad timing apear on his device. I asked him about that and he told me to wait. But he never told me as i forgot to ask him again
Get some oil into thise cylinders and crank for 15 seconds, rest for 30. See if you can get some firing after three such cycles
- 992 Views
Last post by tmmike80
- 3500 Views
Last post by Empathron
- 4556 Views
- 10 Replies
- 3582 Views
Last post by southofmotown
- 1304 Views
Last post by 98v70xc206
