Does this look like I need to replace the radiator?
marklawder
- Year and Model: 1995 850
My research says this is a common leak on 850s. Going to be ordering a new rad and transmission clips now I guess...
- aaaa123.jpg (149.04 KiB) Viewed 1303 times
- aaa1234.jpg (121.75 KiB) Viewed 1303 times
- Has thanked: 2200 times
Unfortunately yes. The radiator takes more strain at the top as the engine torque puts more strain on the top hose area and the plastic/metal portion fails.
First check it isn't just a failing/hard top hose.
If it is the radiator, change the top hose with a good quality item (NOT URO/APA), especially if using a none OE radiator as they don't have the metal insert in the upper outlet and tend to not seal 'round' so an old pipe will not deform to make up the gap.
marklawder
Seems to be seeping out between the plastic and metal portions. Top hose is sealed up. Will I need a new bottom hose as well or just the top one? Was going with the nissens brand radiator from fcp.
FastYellow
- Year and Model: 850 T5-R 1995
What brand is consider Volvo OEM?
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Make sure you replace those rusty clamps.
- dosbricks
- Been thanked: 4 times
ValeoFastYellow wrote:What brand is consider Volvo OEM?
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
Just wanted to chime in that I replaced my old original radiator with a new Valeo/Volvo OEM radiator on my '97 855 GLT about three years ago and the Valeo has been working fine since then, as expected. So far, so good.
I wrote up a little 'diy' on the change-out here:
https://www.matthewsvolvosite.com/forums ... hp?t=55629
4 years on my Nissens with no problems
- pkc303
- Year and Model: 1995 T-5R Yellow
- Been thanked: 3 times
I would also take a look at the motor mounts. The engine sinking puts pressure on that upper radiator hose cracking the plastic radiator. I used Volvo brand on the radiator and the hoses.
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
- 1153 Views
Last post by erikv11
- 2171 Views
Last post by MDK
- 1012 Views
Last post by wizechatmgr
- 10 Replies
- 2979 Views
Last post by bmdubya1198
- 276 Views
