Does this look like I need to replace the radiator?
marklawder
Year and Model: 1995 850
Post by marklawder »
My research says this is a common leak on 850s. Going to be ordering a new rad and transmission clips now I guess...
Has thanked: 2202 times
Been thanked: 1852 times
Unfortunately yes. The radiator takes more strain at the top as the engine torque puts more strain on the top hose area and the plastic/metal portion fails.
First check it isn't just a failing/hard top hose.
If it is the radiator, change the top hose with a good quality item (NOT URO/APA), especially if using a none OE radiator as they don't have the metal insert in the upper outlet and tend to not seal 'round' so an old pipe will not deform to make up the gap.
marklawder
Seems to be seeping out between the plastic and metal portions. Top hose is sealed up. Will I need a new bottom hose as well or just the top one? Was going with the nissens brand radiator from fcp.
FastYellow
Year and Model: 850 T5-R 1995
Post by FastYellow »
What brand is consider Volvo OEM?
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Make sure you replace those rusty clamps.
dosbricks
Been thanked: 4 times
Post by dosbricks »
FastYellow wrote:What brand is consider Volvo OEM?
Valeo
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
Just wanted to chime in that I replaced my old original radiator with a new Valeo/Volvo OEM radiator on my '97 855 GLT about three years ago and the Valeo has been working fine since then, as expected. So far, so good.
I wrote up a little 'diy' on the change-out here:
https://www.matthewsvolvosite.com/forums ... hp?t=55629
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
Yes, replace the radiator ASAP.
85 GLH, 367 whp
00 Insight, 72 mpg
Been thanked: 4068 times
4 years on my Nissens with no problems
pkc303
Year and Model: 1995 T-5R Yellow
Been thanked: 3 times
Post by pkc303 »
I would also take a look at the motor mounts. The engine sinking puts pressure on that upper radiator hose cracking the plastic radiator. I used Volvo brand on the radiator and the hoses.
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
