Key doesn't lock or unlock but remote does-02 V70
neworleans
Year and Model: 2007 S60R
Post by neworleans »
Hello everyone.
I am having a problem with the door lock, the key doesn't lock or unlock the door but remote does. The problem is the driver door is the only door that has a key insert. Do you think this is an easy fix? My concern is that if the battery dies and remote doesn't function, is there any way to unlock the doors or pop up the hood?
Thanks.
mydamnvolvo
Year and Model: Lots
Post by mydamnvolvo »
Your ignition may have been replaced if you bought the vehicle second hand. Then, there would be a key for the door and a key for the ignition.
Current:
00 V70 (Daily)
01 V70 (Trips)
94 300zx (High School Present)
01 V70 (Hub)
08 GranCher (Daught)
01 740iL
09 C40 (Son)
Former:
93 BMW 525i-Daugh's-Seized
02 Chrysler T & C-Kid Hauler-Fire
72 Buick GSX-Dad's-Corroded
76 Golf GTI-Mom's-Died
97 960-1st-Timing
Been thanked: 4065 times
I think you can still get in through the trunk on an 2002...on my 2005 you are really stuck if the key and fob stop working
neworleans
When insterted the key, it turns on either side but doesn't unlock the pin, also when you shake the door, i hear something loose.
How would you get in through the trunk? Is there a trick?
nsjames
Year and Model: 04 XC70
Post by nsjames »
the linkage has fallen off inside the door.
remove the door card and put it back. you may need some new plastic bushings/keepers if they've broken.
