PCV pressure
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Which oil viscosity is used for engine?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
FastYellow
- Year and Model: 850 T5-R 1995
Compression test was done on a hot engine. I took it out for a 30 min drive. Then checked numbers.
I am using Quaker State 10w-40 conventional oil on the engine. I will be switching to full synthetic as soon as I replace PCV system and get an idea where the tailpipe smoke is coming from
- Has thanked: 312 times
- Been thanked: 818 times
Sounds like a good plan.
- misha
Synthetic oil is a MUST for turbo engine.Don't push your luck!
Stay with xx-40 weight,don't go with xx-30.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
FastYellow
Do you guys think I should check out the PTC and see if its clogged or should I just wait till I get the PCV system. I ordered it from FCP should be here in the next few days
- misha
Why not?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Wouldn't hurt but you will still need to check and clean the whole PCV. If you don't check the PTC now, for sure do it later.
FastYellow
Ok. Now when car starts NO smoke. I cleaned PCT very well.
When temps are warming up now I'm getting CONSTANT smoke out the tailpipe (grayish with a hint of blue) even at idle. When revved it intensified.
I'm leaning towards TURBO? 227k ECU verified mileage. OEM 15g turbo. Can turbo seals be the now CONSTANT smoking culprit?
- 1143 Views
Last post by Ben850
- 644 Views
Last post by gkrogman
- 12 Replies
- 4172 Views
Last post by ShaverNS1
- 1453 Views
Last post by erikv11
- 702 Views
Last post by ThommyKent
