Will a V70 headliner fit an 850
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
You can take the sunroof out without removing the headliner. https://www.matthewsvolvosite.com/forums ... 0393#30393
As far as the headliner goes I think it might. If you can check to make sure the grab handles, sun visors, and rear clips are all the same on both cars then I think you can reasonably assume the headliners can be swapped.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Yes. I put one in my car. Be sure to clean out the cabin fans.
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
I believe the climate control temperature sensor will not match. 850 has em in the headliner, V70 doesn't.
If I'm not wrong about that, you can probably make a cutout in the V70 headliner to match, but I'd look closely at both parts before taking the dive.
- skloon
- Year and Model: 94 850 95 850 04 S60
- Been thanked: 2 times
My sunroof has broken tracks so I have to drop the headliner- I will check it before I yank it out- I did pull my fans and clean the plug of crap out of them -luckilly a wagon so easier to pull the liner and it is half price at the yard
Did the V70 headliner fit into the 850? If so, how did you deal with the climate sensors by the front grab handles?
I need to replace my 850 Wagon headliner and wondering if this is still a good option.
1996 850 Turbo Wagon - 175K miles, ARD Green ECU, Koni FSD, IPD sways, Snabb intake pipe, IPD HD TCV
1999 V70 T5M - 220K miles, M56H swapped, 2004 S60T5 engine, IPD sways, H&R springs, Bilsteins, TME catback, tune
2007 V70R, 55K miles, mostly stock
- 12 Replies
- 561 Views
- 26 Replies
- 6915 Views
Last post by 98v70dad
- 1610 Views
Last post by jcdillin
- 384 Views
Last post by Baptiste1106
- 9 Replies
- 2914 Views
Last post by rspi
