Gates timing belt kit.
PS78
Year and Model: 2000 S70
Has thanked: 2 times
Been thanked: 3 times
Post by PS78 »
Was wondering if anyone has used this timing belt kit. Looking for some thoughts on it.
The price is definitely good.
Always first off the line, while all the cool people are still staring at their phones.
Cees Klumper
Year and Model: 2002 S80 T6
Has thanked: 46 times
Been thanked: 33 times
Post by Cees Klumper »
Others with far more knowledge will weigh in, but, for me, this is one of the few items I would not be looking to economize even a large-ish amount like $100, given the amount of work, driticality of function, and length of time this will need to perform.
PS78
Post by PS78 »
Fair enough and i agree. I've read some really bad things about the water pump catastrophically failing on different makes so I'm going to dismiss this set. I won't take chances on mission critical components. Any suggestions for a good kit or is a better idea to buy the components separately?
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 37 times
Post by theWIFES_S70 »
Go with a kit from FCP https://www.fcpeuro.com/products/volvo- ... it331wp198, if you're feeling adventurous and want to remove cams! 8) Otherwise, just get the OEM idler, pulley and mechanical tensioner and an Aisin or Hepu water pump. You can get a Volvo belt or a Continental belt, both have a following. Good luck with the job!
Retired:
2015 Volvo S60, T5, 85K
PS78
Post by PS78 »
Thank you for the link, looks good. I do want to be thorough and replace the seals while I'm in there also. I'm doing a sort of once over of the car. I'm also looking into the atf brands right now. I know my vast gets the 3309 spec and I've been reading about the idemitsu fluids. Voyage of discovery dudes..ha ha
theWIFES_S70
I spent two days non-stop researching every Gl-4 transmission fluid available in the U.S. for our car. (Posted the information here, my first post ever.) I understand your voyage entirely! :) My cam seals looked good at 150K so I let them be. I know at the next timing belt change, I'll definitely get that kit. (And I'll have to replace the lower timing belt cover that I cracked...) Good luck!
Retired:
PS78
Post by PS78 »
Thanks. Yeah the cam seals look like fun. I have had a really positive experience with redline mt-90 in my other car. It took some research to get me there. If I remember correctly most of if not all the manual gear oils available were for a higher classification standard than i needed and caused shudder. I keep seeing mobil 1 js3309 for this car or Toyota type 4 So I'll keep doing my homework.
Has thanked: 311 times
Been thanked: 817 times
Ugh. Elring cam seals = crap. No go on that kit from FCP!
Of course it is fine to replace front cam seals as preventive maintenance but it is not really warranted. I will not replace front seals unless I have the cam cover off anyway (have done that a few times now) or they are leaking (never had one leak yet). If you want to do the seals, buy Corteco.
Gates timing belt kit - pass, as others have stated. Timing belt parts from Volvo will run you about $120 for belt-idler-tensioner, Aisin water pump wherever it is cheapest (i.e., as per Marco's post).
PS78
Post by PS78 »
Yeah I'm definitely not bothering with the gates kit. I'll look around and put the set together from the info gained here. Thanks guys.
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
New data I read recently suggests that Elring have their seals provided by Corteco which is the OEM supplier.
Perhaps they had a production problem and had to outsoirce on some of their batches. Elring have their btandname stamped on them. Corteco have distinct markings but no brand name.
