there are two terminal resistors in the low speed can network 60ohms each
if you disconnect the battery and check the resistance on the network you should get 120ohms or 60ohms i cant remember.
anything other than that is bad.
i always check at the power seat module connector because its easy to get to. its a green connector and the can wires are solid green and solid white and they are twisted together. check the resistance and it should be 120 or 60 ohms.
this wont help finding which module is causing the problem, but you can disconnect modules until the reading comes into range.
this is a hard way to diagnose the problem without vida
"Brake Failure Stop Safey ASAP" - major electrical issue
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
Do you have "Alarm system service required" message?Kingstate wrote:My 2001 s60 locks sunroof and trunk all stop working today, Ive checked the fuses and they all look good, anyone with any help besides going to the dealer please let me know.
- 2490 Views
Last post by dandiman
- 1096 Views
Last post by hiroshima1320
- 44 Replies
- 16952 Views
- 6177 Views
Last post by mf70
- 11 Replies
- 8306 Views
Last post by ggleavitt
