'96 850 paint peeling
Teddy1975
Year and Model: 2007 V50
Been thanked: 7 times
Post by Teddy1975 »
The 850 I have has started to shed its skin. I don't believe it'll grow in a new skin, like a spider would though, so I really do want to do something about it.
What seems to be happening is the clear top coat is coming apart from the colour layer and when a large enough piece is loose, it'll fall off. Some of the pieces I've seen were more than a square inch in size. I don't have any pictures to show of it as of now, I'll see if I can take some tomorrow.
I'm mostly worried about these spots with no clear coat will turn into rust and hoping to avoid a respray as that is definately out of the question.
Is there any way to stop the peeling before my Volvo ends up naked and embaressed? :lol:
Current: V50 2.0D, 2007, 6 speed manual
Previous: 850 2.0L N/A, 4 door 1996 manual, 740 2.3L N/A, 5 door 1992 manual, and S70 2.5T 1999 manual
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
I'd strip the rest of the clear coat and re-clear it. I'm not sure you can wax the base coat like you can with the clear.
kahl
Year and Model: 2000V70XC
Been thanked: 10 times
Post by kahl »
On our 94 850 the roof started to peel. Tried to sand off clear coat and respray.....turned ugly fast. Had to color coat then clear.
Teddy1975
Post by Teddy1975 »
On mine it's mostly on the hood, at least that's where I noticed it.
Khal, did you remove the color that was on it or rough it up, then color and clear coat it?
kahl
Post by kahl »
Sanded the roof down then primed, color then clear.
skloon
Year and Model: 94 850 95 850 04 S60
Post by skloon »
If clear is peeling then all you can do is sand it down you may be able to re-clear but probably not if just the roof you could wrap it
bmdubya1198
skloon wrote:If clear is peeling then all you can do is sand it down you may be able to re-clear but probably not if just the roof you could wrap it
Your best option, right here. Sand and repaint. With any luck, you won't go through the base coat and you can just re-clear it.
Vinyl wrap wouldn't be an awful option. It's a PITA, though... my interior trim wrap attempt went terribly.
benpineapple
Year and Model: '06 V50 T5, '13 XC90
Has thanked: 5 times
Been thanked: 4 times
Post by benpineapple »
I agree, sand and repaint. Unless you sand, you have no sure idea what you're trapping in the layers of paint.
Do you guys use a pneumatic spray paint gun for the base and clear? I'm going to be fixing a couple small rust spots this summer. I had a local paint shop make some custom paint in spray-can form that matched my white 1990 240. But I've got my 98 V70 now, paint is much more complex on this car haha.
2006 V50 T5 [190,xxxM]
2013 XC90 FWD [80,xxxM]
2001 V70 X/C AWD [sold at 120xxxM],1998 V70 AWD [RIP at 249,255M], 1990 240 [SOLD at 220xxxM]
Teddy1975
Post by Teddy1975 »
I snapped a couple of pictures of the culprit today and had a closer look at the other panels on the car.
Both wings have started to rust in the usual spots (lower side next to door and next to the head lights). And the boot lid is rusted through in the lower left hand corner. PO had taped it up seemingly a long time ago and never bothered dealing with it. At least I know how to weld/solder so just have to wait for warmer weather for that job.
The clear coat lifting on the hood is probably due to stone chips, as you can see from the first picture.
Yellow circle seems to be where a stone has hit the paint.
Larger area of clear coat having lifted and vanished.
There are a lot of stone chips all over the hood so I'm thinking maybe the vinyl wrap wouldn't be such a bad idea after all. Have anyone tried that and if so, how does it look over time?
pkc303
Year and Model: 1995 T-5R Yellow
Been thanked: 3 times
Post by pkc303 »
You could try to sand and then clear it with rattle can clear, but honestly it is postponing the inevitable.
I have the same problem on my 1997 850R, and the 1995 T5-R had the same problem. Had to do a full paint job. Did it myself, with some good advice from a friend. Lots of work, and still not done, because one thig leads to another, and the next thing you know, you are doing a full restore.
Good luck.
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
