A friend of mine borrowed my S60, returned it to me with transmission problem. Car won't go into gear, only when reved high, it barely moves, but if pushed it will get going and once momentum is built it drives fine, until I get to a stop sign, then have to start over again. Also, found this part in the cup holder (see pics).....does anyone know where it might be from? Looks/smells like gear oil??
Thanks
unknown transmission component
figmaister
- Year and Model: 2006 S60 2.5T AWD
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Looks like the part snapped from some where. Can you see a part number on it?
figmaister
Unfortunately no part number
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
You are describing the limp home setting of transmission. It takes off in 3rd gear so it is gutless but once you get to the speed range where it would be in 3rd gear normally it feels normal.
I am fairly sure that is not a part from a volvo. It looks like a broken piece of a rubber damped serpentine belt tensioner but your car does not use one of those.
Is there any message in instrument cluster about tranmission? Check engine light on?
- Has thanked: 1611 times
- Been thanked: 4071 times
Almost looks like part of a seat adjuster but both the thread and the casting are broken,so it's a part of a part problem
- oragex
The transmission might be in the W mode? Do you see a D or a W on the instrument panel under the Rpm gauge?
figmaister
Jimmy57,jimmy57 wrote:You are describing the limp home setting of transmission. It takes off in 3rd gear so it is gutless but once you get to the speed range where it would be in 3rd gear normally it feels normal.
What could cause the transmission to go into limp mode? Electrical or mechanical issue, or both?
Thanks
It really can be either. Thats why you need the codes to get started on diagnosis. There are so many failure mechanisms on electronically controlled cars you can't trouble shoot it by symptom anymore.figmaister wrote:Jimmy57,jimmy57 wrote:You are describing the limp home setting of transmission. It takes off in 3rd gear so it is gutless but once you get to the speed range where it would be in 3rd gear normally it feels normal.
Thanks
- 1055 Views
Last post by importCar
- 579 Views
- 18 Replies
- 8734 Views
Last post by rspi
- 16 Replies
- 15464 Views
Last post by Fernandomiguel
- 2154 Views
Last post by RSalzman
