V70XC 2000 Intermittent non-starting
instarx
Year and Model: XC70 T6 2011
Post by instarx »
I am experiencing a strange non-start situation once a week or so.
When I crank the engine it starts but only runs for a second or less and shuts off. It doesn't stumble or sputter - it just shuts off. After that it will crank but not start. I hear the fuel pump when I turn the key even in the no-start situations. If I wait for just 3-4 minutes without cranking it starts right up. At first I thought it was a fuel heating issue since it seemed to be happening when the engine was warm, but this morning it happened when the engine was completely cold. It had been sitting overnight, I cranked it, it started and shut off immediately with a little cough. It started fine five minutes later.
Any ideas?
The engine runs very well otherwise.
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 74 times
Post by FlyingVolvo »
I have a very similar issue that happens at about the same regularity as yours. Maybe once every 20 starts or so. Fires up, immediately turns off (like yours, no roughness or bad sounds), and will crank but not start no matter how long I try. All I have to do to get it working again is bring the ignition to OFF once, and then I can crank and all is normal.
Sorry I'm not any help, but I figure I'd add this to help the solve the mystery.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Any codes?
instarx
Post by instarx »
ecbsykes wrote:I have a very similar issue that happens at about the same regularity as yours. Maybe once every 20 starts or so. Fires up, immediately turns off (like yours, no roughness or bad sounds), and will crank but not start no matter how long I try. All I have to do to get it working again is bring the ignition to OFF once, and then I can crank and all is normal.
I think this is a help. I hadn't tried turning the key off. But when I was letting it sit for 3-4 minutes of course I always turned the key off! Thanks, I'll try turning it OFF immediately next time. Very helpful.
I haven't checked for codes - I'll do that tomorrow.
2011 XC60 - sold
FlyingVolvo
I'll be interested to hear if yours works again immediately like mine. Sounds like we have the same problem, same model and year too!
No codes on mine other than the cat converter code which is now a permanent feature.
2023 V60 T8 PE
Been thanked: 4069 times
A few seconds of running after start is a classic immobiliser problem - on ME7 if the antitheft module glitches the spark is shut off after it fires.
The other suspect is ignition switch, electrical part.
VIDA will sort out which is which vs parts lottery.
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
^^This.
Try unplugging the key antenna connector and use contact cleaner on the connection. That usually fixes it.
The clamshell around the steering column needs to come off to get to it but that is only three torx screws.
northern_dweller
Year and Model: 2000 V70 XC
Post by northern_dweller »
I have a very similar issue with my 2000 V70XC. I have a P0014 code "Cam Position Activator B, Bank 1, Timing Over Advance" that comes on occasionally and does not seem to affect how the engine runs.
At first there was no reason to think that this code was at all related to the occasional no-start condition but now I am starting to see a connection. I only get the code occasionally, probably every 250-500 miles driven. The last two times that it happened, I cleared the code using a code reader and the very next time I tried to start the car it started for about a second and then died. After removing the key from the ignition and trying a few times, the engine starts and runs fine.
I have had the no-start condition before I ever saw the P0014 code and have been trying to figure it out for months.
jim52540
Post by jim52540 »
Have you checked the fuel pump relay. The two capacitors in the relay go bad after about 175,000 miles and result in the symptoms you describe. Can you hear the fuel pump buss for a couple seconds when you turn the key to verify it is getting current from the fuel pump relay?
Try jumping the fuel pump relay with a fused wire and seeing if the problem goes away, almost free to try!
