Head gasket or new motor?
DeanY
Year and Model: 07 xc70
Post by DeanY »
Hi all . 07 xc70 with the missing coolant issue. Replaced water pump,hoses,thermostat, coolant cap. I can't find the coolant leek. Top radiator hose gets hard until I release pressure. Car does not over heat,but add coolant light goes on. Does not misfire or have coolant in oil. What gives,anyone else been thru this ? Thanks
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
When you open expansion tank (not on a running or hot engine), does the level restores?
DeanY
Post by DeanY »
Yes,coolant rushes in tank. I forgot to add I replaced radiator too.
Maybe I need to bring it to get flushed and a pressurized refill?
vtl
Post by vtl »
That's a gasket.
DeanY
Post by DeanY »
Even with no compression leak or misfire?
vtl
Post by vtl »
Did you do compression test?
DeanY
Post by DeanY »
No I haven't. The car runs fine,temp gauge stays in the middle. I
nsjames
Year and Model: 04 XC70
Post by nsjames »
DeanY wrote:Even with no compression leak or misfire?
quite possible.
have the coolant checked for exhaust gas.
https://www.amazon.com/UVIEW-560000-Comb ... B000NPDL76
JudgeRat
Year and Model: s60 2004
Has thanked: 3 times
Post by JudgeRat »
^^what he said. Check for exhaust gas in coolant. I had a similar issue when my head gasket went out with an internal leak to cylinder #1 on mine in the past. Not a fun situation.
"Molly" - Black 2004 2.4L i5 (non-turbo) T5 Auto FWD P2 Volvo s60 w/all options
Old-school race guy: "Brakes 1st, then steering, tires, wheels, & suspension, only then engine and drive-train. No sense making it go if you can't stop & steer properly...Safety first people!"
DeanY
Post by DeanY »
Thanks for the replies folks.It seems to be a head gasket.
Going to the shop Monday. Anything else I should replace while it's there? Already did timing belt and water pump.
Thanks
