Hi guys.
While trying to remove the flame trap on my car today, I noticed a small rubber hose had collapsed and pretty much disintegrated when I tried to remove it.
When cleaning out the gunk and burnt oil I saw the nipple for that small hose was completely blocked and I've tried to clean it as best as I could using a small drill bit. Is there supposed to be hole through the nipple into the housing part 13 in the picture attached, or is it a vacuum switch?
What connects up to the flame trap via hose 19 and is it essential? It's somewhere behind the throttle body and kind of hard to get to the pipe that the hose was connected to.
Thanks,
Teddy
1996 850 N/A PCV - Flame trap
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Teddy, that stuff needs to be REPLACED. It gets old and brittle, deteriorates and falls apart. Yes it is important for it to be together to work properly.
Teddy1975
- Year and Model: 2007 V50
- Been thanked: 7 times
Ack... Yeah I figured so.
Reaching out to the stealership now...
Still I wonder what the hose with number 20 connects up to.
Current: V50 2.0D, 2007, 6 speed manual
Previous: 850 2.0L N/A, 4 door 1996 manual, 740 2.3L N/A, 5 door 1992 manual, and S70 2.5T 1999 manual
Teddy1975
$23.15 including tax for 13, 14, 15, 18 and 19 was much less than I feared.
Thanks, Robert.
Thanks, Robert.
- Has thanked: 311 times
- Been thanked: 817 times
Don't bother replacing 15, just throw it away, leave the housing empty inside. All that flame trap disc does is get clogged up.
You can also replace 18-19-20 with a few cm of generic rubber vacuum line.
Did you figure out where 20 connects? Vacuum tree maybe?
Look for a vacuum diagram under your hood - it will show where your hoses attach
Maybe.
Maybe.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Number 20 on non turbo car is going at left side of intake manifold,in power steering and alternator area.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Teddy1975
I haven't found more info on #20 yet... I might find out tomorrow when I've picked up the parts from the independent OE dealer.
I know people say to just throw away the flame trap, but since it really doesn't cost an arm and a leg ($8); and it's easy to replace, I'll replace/clean it when I do the yearly service anyway. I'd rather have the filter catching the bigger chunks of burnt oil before it gets into the TB and engine.
I thought the whole point of the question was that this is not a standard setup but if there is an open nipple on the manifold then yeah, that is where 20 would connect.
Teddy1975
Well, the open end is what connects to the flame trap housing. I was just curious as to where it leads as the picture from VADIS isn't really making it clear.
I'll look at it more closely in real life tomorrow, when I have the parts. It would probably make sense to replace the PCV system completely now that I am going to mess about with part of it anyway.
- 1695 Views
Last post by 93Regina
- 716 Views
Last post by Ozark Lee
- 1490 Views
Last post by callahanoffroad
- 12 Replies
- 2589 Views
Last post by erikv11
- 711 Views
Last post by GlennG2759
