98 s70 GLT Misfire
- misha
- Has thanked: 155 times
- Been thanked: 432 times
It's lpt.
I think that spark plugs are wrong for that car or not properly gapped.Gap is crytical for turbo engines.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Been thanked: 4068 times
At some point, and you are past this point, you stop thinking about what you have recently done and start troubleshooting.
You start with a compression test to make sure your engine internals are in good shape.Then you go to spark. Then you go to fuel. Finally you go to timing.
The whole time, you stop looking for the 'one thing' that is causing your problem and allow that you may have multiple things wrong.
- Has thanked: 311 times
- Been thanked: 817 times
That plug is fine, my 98 GLT had Autolite 3923 plugs when I got the car, I eventually changed them out but they gave no problems. Open up the gap a little, check it carefully.erikv11 wrote:Yeah OK that 3923 Autolite plug should be fine on a 98 LPT, gapped 0.028 to 0.030. Check into Robert's intake idea too.
The first step of troubleshooting is visual inspection, especially when something new shows up immediately after working on the car. Some things to check:
- crank sensor wires and connector
- cam sensor wires and connector
- ALL vacuum lines including brake booster; check really carefully even better use starting fluid, these are a pain. I just replace them all when I get a car.
- engine grounds, there are a couple on top of the engine, did they get broken? Clean their attachments, anyway.
- test the MAF it is a free and easy test and yes it could be the cause
i- nspect the distributor cap and rotor, is the cap clean inside, is there any sign of arcing? Cap and rotor must be Bosch, no way around it.
Failed electronics in the rotor will give exactly these symptoms, have seen it several times. Unfortunately that one the only way to check is to swap in a good one.
There are a lot of possibilities you will be better off if you are systematic and actually check each thing, not say "oh I think that one is probably OK."
well i regapped the plugs now only missing on cylinders 2 and 4 no more 5.. maybe i have them gapped to little everything else is fine no air leaks good compression on all 5 rotor and cap looks great
Low RPMs coming to a stop is usually a vacuum leak.
Bucking and surging could be the MAF. Testing the MAF it is a free and easy. Unplug the MAF, then start the car and drive it around. If that makes the problem go away then the MAF is bad.
- misha
Now you have a Maf symptoms erikv11 was mentioned in some previous post.
Disconnect it,start the car and see if it runs better.
How did you solved misfiring problem?What was the problem,gap?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 19 Replies
- 10240 Views
Last post by Barledge
- 215 Views
- 949 Views
Last post by stephansvolvo
- 1644 Views
Last post by AD_NAPCO
- 2431 Views
Last post by jmorman
