Hi!
THe other day I thought I´d use the A/C a bit so it won´t seize. Themperature was in the range of 55-60 degrees. The compressor came on and off while driving which is normal, I´d say if the exterior temp is lower than the interior temp. But then I set both climate control knobs to min, opened the hood and expected the compressor to run all of the time. But it came on for a few seconds, then off for a few, then back on.
Keeps me wondering: Is taht normal even if the AC is set to min? Or is this an issue with the clutch gap or am I in Need of an AC Service/refill?
It worked alright last year.
Btw, it´s a 96 855 R.
should the A/C compressor be on all the time when set to min?
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
That's how it works, it's cycling, the compressor doesn't work continuously.
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
A little beside the point but the compressor will also come on to defrost the windshield. So if you've been using the defrost function during the winter you don't need to worry about the compressor seizing.
- Clemens
- Has thanked: 500 times
- Been thanked: 228 times
Thanks for the input. Today I did some testing and it seems like the System pressure is too low. So I guess I´ll Need a refill at least. Hopefully not the evap.
Speaking of the devil (evap): anyone ever tried to fix a bad evap with some sorta AC sealant? Given the hassle of taking all that apart (and putting it back together correctly) it might be worth a try.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- Has thanked: 1611 times
- Been thanked: 4072 times
Using sealant is 1000 USD roulette. The orfice tube on these systems is small and it is easy to plug.
The only fix for leaking AC is replacing bad parts ..in this case almost certainly the evap.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
No it will not if outside temperature is below 2 degrees Celsius.polskamafia mjl wrote:A little beside the point but the compressor will also come on to defrost the windshield. So if you've been using the defrost function during the winter you don't need to worry about the compressor seizing.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
In the summer temperatures,when system is properly charged and pressures ok,compressor will run all the time without cycling.oragex wrote:That's how it works, it's cycling, the compressor doesn't work continuously.
It starts cycling when refrigerant level drops,or when outside temperatures are colder.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
polskamafia mjl
misha wrote:No it will not if outside temperature is below 2 degrees Celsius.polskamafia mjl wrote:A little beside the point but the compressor will also come on to defrost the windshield. So if you've been using the defrost function during the winter you don't need to worry about the compressor seizing.
You may be right, Misha, although I've never heard that before but it does surprise me. Where did you read that?
- misha
No need to read...try it and you will see.
That's a protection for ac compressor from seizing.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
