Hello! I've got 2 driveshaft questions.
I have a 98 V70 with tape over its AWD emblem, until I fix it. I don't want to replace the shaft with a brand new shaft, in the event that something else is the problem too. So a local pick 'n pull just got in a 2000 V70 AWD, and I'm wondering if the driveshafts are compatible. I've been doing research by comparing driveshafts, and some say non-compatible, while a few I've found say that 98-00 are compatible.
Also, driveshafts for the proper model are determined by using the last 6 numbers of the VIN (chassis number?), and my VIN does not line up with any driveshaft VIN ranges. Most say something to the extent of "VINs 46xxxx - 64xxxx", the last 6 of my VIN are: 445557. I'm assuming it's an early 1998 model.
Thanks! Any insight would be great. I might just go to the pick 'n pull and yank it for the ole trial and error method. Not having the AWD has been brutal in Michigan, with the massive storms we've been getting.
Compatible Rear Driveshafts for 1997-2000 V70 awd
benpineapple
- Year and Model: '06 V50 T5, '13 XC90
- Has thanked: 5 times
- Been thanked: 4 times
2006 V50 T5 [190,xxxM]
2013 XC90 FWD [80,xxxM]
2001 V70 X/C AWD [sold at 120xxxM],1998 V70 AWD [RIP at 249,255M], 1990 240 [SOLD at 220xxxM]
- Has thanked: 2210 times
I will check, but I know there were I believe 3 different prop-shafts (between angle gear and VC). The first one was fitted to 97 850 AWD (only came in stick shift), and up to mid year approx. 98 S/V/XC 70 AWD models. There was I believe another version and I know 2000 is different to 98. It is mainly to do with different flange sizes. Theoretically if you can swap the VC and angle gear output flanges you may be able to fit the 2000 to a 98.
VIDA only shows 2 versions:
1) V70/V70XC to chassis - 630091 part # 9183941
2) V70/V70XC from chassis - 630092 on part # 946300
If I recall one of the 2 has a 95mm O/D flange and the other was smaller (perhaps 93mm?)
Vida is confusing as if you check under 98 V70 AWD it then gives 3 versions:
1) Chassis - 465398 part # 8602507 ( which replaced part # 8251731)
2) Chassis - 465399 to 482860 part # is not listed
3) Chassis - 482861 to 630091 part # 9183941
4) Chassis - 630092 on part # 9463300.
So this would suggest there could be 4 versions available. Easiest answer is to measure the front and rear flange OD at the VC and angle gear output and use that as your guide.
Colorado Drive shafts may have information on their website or call them. They are very helpful.
benpineapple
Wow, thanks a ton for the resources. Glad I didn't try pulling the driveshaft from the '00, it clearly isn't compatible. Scot850, I'll definitely be measuring the flanges prior to purchasing a driveshaft of any kind. It is still odd to me that none of those driveshafts would be compatible if compatibility is solely based off chassis number, as mine is in the 44xxxx range, rather than the 46xxxx and up. I'll get in touch with the people from Colorado Driveshaft to get a part number, if possible.
Thanks BEJinFbk, fantastic write up on driveshaft differences. Odd how the carrier mount for the 98 and 99 is a different height. Colorado driveshaft has a particular shaft listed as being for either 98 or 99. Carrier must be different for some chassis numbers.
JRL
- Year and Model: Several
- Been thanked: 16 times
Early 98
Late 98 and 99
2000 only
Those are the three
Late 98 and 99
2000 only
Those are the three
blankenship
- Year and Model: 2005 XC90 2.5T
- Has thanked: 3 times
I just purchased a 2000 V70XC that's had the shaft removed, and I'd like to put one back in there.
Chassis # 645736. Does this mean for sure it takes the 9463300 part #?
I saw Dorman makes a driveshaft (# 936870) that's 50% of the cost of OEM ($$$)...but it looks like it might only fit an older chassis, and that there are no aftermarkets made for mine?
Would appreciate any insights or advice; or if anyone in the Portland, OR area has a good used one for sale or bad used one to offer up for reconditioning.
blankenship
'05 XC90 2.5T AWD
days gone by: '71 model 142, '73 model 144, '83 240gl sedan, '88 780 bertone, '90 240dl wagon, '98 v70, '00 XC70
'05 XC90 2.5T AWD
- Has thanked: 1611 times
- Been thanked: 4073 times
2025 update, that link has broken. Info lostBEJinFbk wrote: 26 Feb 2016, 20:00 Been here?
http://v70r.com/forums/topic/33058-98-0 ... omponents/
MUCH Good P80 AWD info!![]()
Info cp on1998 center CVjoint
did some research a few years ago and found the following for 98 ( checking my old notes).
UK company Bailey Morris should have most of what you seek.
Bearing BMCB155 . You cannot just exchange the rubber or ring I think.
U joint GMB1610691 or GKN 1610035 (not sure).
The axle can be split by unbolting the center bolt inside the u joint in order to replace the bearing. Only 98 axle can be split up to chassis number i think 465398.
The bearings of 98 and 99 have the same mounting holes on the carrier, 2000 is different. I think the carrier is still available from volvo.
If you have a later chassis number the bearing would be Bmcb133 and non splittable shaft. U joint also different, don’t know the part nr.
Here are the three versions of propeller shafts for the awd p80s
melmaclifeform
- Year and Model: 2000 S70 GLT SE
- Has thanked: 2 times
- Been thanked: 7 times
First page is still available on Wayback. And apparently the important info was crossposted onto Swedespeed, but I couldn't find it with a cursory search.abscate wrote: 29 Jul 2025, 04:292025 update, that link has broken. Info lostBEJinFbk wrote: 26 Feb 2016, 20:00 Been here?
https://web.archive.org/web/20190906043 ... ts/?page=2
2000 S70 GLT SE
1997 Volvo 850 T5
2011 Volkswagen Jetta SE
1999 Mazda Miata
1997 Volvo 850 T5
1999 Mazda Miata
- 1308 Views
- 972 Views
Last post by xHeart
- 541 Views
- 406 Views
- 909 Views
Last post by precopster
